Hi folks, I would like to share with you my project.
It is an Arduino based alarm system which consists of 4x4 matrix keypad, 16x02 LCD screen connected to board using 2-wire schematic on 74LS164 and ATmega328p.
Could you please help me make it work on an normal parallel LCD shield that I usually initialize with LiquidCrystal lcd(8, 9, 4, 5, 6, 7); [ it is this model: Gravity: 1602 LCD Keypad Shield For Arduino - DFRobot ]
I am guessing I should modify something here:
ShiftRegLCDExt::ShiftRegLCDExt(uint8_t srdata, uint8_t srclock, uint8_t srbacklight, uint8_t enable, uint8_t lines)
: ShiftRegLCD(srdata, srclock, enable, lines), pinBacklight(srbacklight), lcdBacklightOnTime(0) and init with LiquidCrystal instead of ShiftRegLCD
So can you please please help me out with this init?
I have a 74hc595n chip, on the site off the picture (Google Code Archive - Long-term storage for Google Code Project Hosting.) I found a schematic for my chip, the circuit is great, but I think i have to modify the code to make it work
I can get only random letters.
if I use the solution from oby_one I get an error!
can you help me?
Thanks
(I have a b50k potentiometer for the contrast (works great) , a 74hc595n chip.)
