I'm looking to develop a Clock Distribution Network, based on Arduino, I've never built a Clock Distribution Network before so am looking for some advice.
My goal is to have one Arduino generate and send both a clock and sync signal to 4 ICs (nodes), up to 100m away, which will then require a repeater to amplify the clock signal so that it can be effectively read by the IC nodes. What would be the best way to set this up? Is it through Arduino or could a more simple circuit-based approach have the same effect?
Also, the clock signal needs to be 38.4 MHz. Can I use a larger clock and then divide this on the Arduino to send to the ICs?
There is also the opportunity to combine the Sync and Clock signals, but this seems like a more complex approach?
The Arduino Uno has a 16MHz clock and the Arduino Due has an 84MHz clock, so either way, I don't see how you can get 38.4Mhz. Using an Arduino as an oscillator might not be the best approach.
I bought 6 DWM1000 for my study .
This is what I learn ,
I want to do TDoA, which require clock and sync signal.The most painful thing is that these only available on DW1000, so get back to DW1000??
NO. DW1000 calibration will be a nightmare and only I have seen Loligo and OpenRTLS use the DW1000.
