This is the code for Arduino GLCD based oscilloscope, can anyone help me because every thing is working as expected but frequency is not showing also voltage.
here is the code
#include <U8glib.h>
U8GLIB_KS0108_128 u8g(2, 3, 4, 5, 6, 7, 8, 9, A3, A4, A5, A1, A2);
int Input = A0;
int Key_add = 0;
int Key_sub = 1;
int Key_hold = 10;
int x,y;
int i,i1,i2,V_min,V_max,V_mid,t,t0,t1,sta,Key=1,hold=0;
long Freq;
float Vpp;
int Y[96];
int Buffer[192];
const uint8_t L[] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x00, 0x00,
0x00, 0x0F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00,
0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00,
0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00,
0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60,
0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20,
0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10,
0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10,
0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x00, 0x00, 0xFF, 0xFC, 0x00, 0x00, 0xC0, 0x01, 0x80, 0x60, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x00, 0x00, 0xFF, 0xFC, 0x00, 0x01, 0xC0, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0x00, 0x01, 0xE3, 0xDF, 0xB6, 0x6F, 0x8F, 0x00, 0x00, 0x08,
0x10, 0x00, 0x00, 0x03, 0x8F, 0xFF, 0x00, 0x01, 0xE3, 0x1B, 0xB6, 0x6D, 0x9B, 0x80, 0x00, 0x08,
0x10, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0x00, 0x03, 0x33, 0x31, 0xB6, 0x6C, 0xB1, 0x80, 0x00, 0x08,
0x10, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0x00, 0x03, 0xF3, 0x31, 0xB6, 0x6C, 0xB1, 0x80, 0x00, 0x08,
0x10, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0x00, 0x06, 0x33, 0x1B, 0xB6, 0x6C, 0x9B, 0x00, 0x00, 0x08,
0x10, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0x00, 0x06, 0x1B, 0x1F, 0xBE, 0x6C, 0x8F, 0x00, 0x00, 0x08,
0x10, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x00, 0x03, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x00, 0x03, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x0C, 0x00, 0x0F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x0C, 0x00, 0x0F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x0C, 0x00, 0x3F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x0E, 0x00, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x0F, 0x1E, 0x3C, 0xF8, 0xF0, 0x00, 0x00, 0x08,
0x10, 0x0E, 0x01, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x0D, 0x93, 0x6E, 0xCD, 0x90, 0x00, 0x00, 0x08,
0x10, 0x0F, 0x87, 0xFF, 0xF9, 0x80, 0x00, 0x00, 0x0F, 0x30, 0xC6, 0xCF, 0xF8, 0x00, 0x00, 0x08,
0x10, 0x0F, 0x87, 0xFF, 0xF9, 0x80, 0x00, 0x00, 0x03, 0xB0, 0xC6, 0xCF, 0x00, 0x00, 0x00, 0x08,
0x10, 0x0F, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x0D, 0x9B, 0x6C, 0xCD, 0xB0, 0x00, 0x00, 0x08,
0x10, 0x0F, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x07, 0x9E, 0x3C, 0xF9, 0xE0, 0x00, 0x00, 0x08,
0x10, 0x0F, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x08,
0x10, 0x03, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x08,
0x10, 0x03, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x7F, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x3F, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x1F, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x07, 0xCF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x07, 0x83, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x06, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x07, 0x83, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x10, 0x00, 0x07, 0x83, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20,
0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40,
0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80,
0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00,
0x00, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00,
0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0x00,
void setup( )
pinMode(Key_add,INPUT);
digitalWrite(Key_add,HIGH);
pinMode(Key_sub,INPUT);
digitalWrite(Key_sub,HIGH);
pinMode(Key_hold,INPUT);
digitalWrite(Key_hold,HIGH);
ADMUX=0x60;
ADCSRA=0xe2;
analogReference(INTERNAL);
u8g.firstPage();
do {
u8g.drawBitmapP( 0, 0, 16, 64, L);
} while( u8g.nextPage() );
delay(2000);
void loop( )
sample( );
Measure( );
Transform( );
Key_scan( );
draw();
if(hold==0)
u8g.firstPage();
do {
draw();
void sample( )
{ for(i = 0;i < 192;i++)
Buffer[i] = ADCH;
switch(Key)
case 1:
case 2:
delayMicroseconds(4);
case 3:
delayMicroseconds(10);
case 4:
delayMicroseconds(23);
case 5:
delayMicroseconds(60);
case 6:
delayMicroseconds(123);
case 7:
delayMicroseconds(248);
case 8:
delayMicroseconds(623);
case 9:
delayMicroseconds(1247);
default:break;
void Measure()
V_max=Buffer[0];
V_min=Buffer[0];
for(i=0;i<192;i++)
if(Buffer[i]>V_max)
V_max=Buffer[i];
if(Buffer[i]<V_min)
V_min=Buffer[i];
V_mid=(V_max+V_min)/2;
Vpp=(V_max-V_min)*5/255;
for(i=0;i<97;i++)
if(Buffer[i]<V_mid&&Buffer[i+1]>=V_mid)
i1=i;
for(i=i1+1;i<98+i1;i++)
i2=i;
t=i2-i1;
if(t>0)
Freq=8000/t;
Freq=0;
void Transform( )
for(sta=0;sta<96;sta++)
if(Buffer[sta]<128&&Buffer[sta+2]>128)
for(i = 0;i < 96;i++)
Y[i] = 63-(Buffer[i+sta]>>2);
void draw()
for(x = 0;x < 95;x++)
u8g.drawLine(x,Y[x],x,Y[x+1]);
u8g.drawFrame(0,0,97,64);
u8g.drawLine(48,0,48,63);
u8g.drawLine(0,32,96,32);
for(x=0;x<96;x+=8)
u8g.drawLine(x,31,x,33);
for(y=0;y<64;y+=8)
u8g.drawLine(47,y,49,y);
for(x=8;x<96;x+=8)
for(y=8;y<64;y+=8)
u8g.drawPixel(x,y);
u8g.drawStr(98,7,"MS/div");
u8g.drawStr(98,23,"V/div");
u8g.drawStr(98,30,"0.324");
u8g.drawStr(98,40,"Vpp");
u8g.setPrintPos( 98, 47);
u8g.print(Vpp);
u8g.drawStr(118,47,"V");
u8g.drawStr(98,55,"F(HZ)");
switch(Key)
case 1:
u8g.drawStr(98,14,"0.02");
u8g.setPrintPos( 98, 62);
u8g.print(Freq*50);
case 2:
u8g.drawStr(98,14,"0.05");
u8g.print(Freq*20);
case 3:
u8g.drawStr(98,14," 0.1");
u8g.print(Freq*10);
case 4:
u8g.drawStr(98,14," 0.2");
u8g.print(Freq*5);
case 5:
u8g.drawStr(98,14," 0.5");
u8g.print(Freq*2);
case 6:
u8g.drawStr(98,14," 1");
u8g.print(Freq);
case 7:
u8g.drawStr(98,14," 2");
u8g.print(Freq/2);
case 8:
u8g.drawStr(98,14," 5");
u8g.print(Freq/5);
case 9:
u8g.drawStr(98,14," 10");
u8g.print(Freq/10);
default:break;
void Key_scan()
if(digitalRead(Key_add)==LOW)
while(digitalRead(Key_add)==LOW);
Key++;
if(Key==10)
Key=9;
delay(10);
if(digitalRead(Key_sub)==LOW)
while(digitalRead(Key_sub)==LOW);
Key--;
if(Key==0)
Key=1;
delay(10);
if(digitalRead(Key_hold)==LOW)
while(digitalRead(Key_hold)==LOW);
hold=~hold;
delay(10);
please help me what to do.. ![]()
