Arduino Bluetooth Heart Rate Monitor
Hi all. I am building a Bluetooth heart rate monitor using an arduino and a HC-05 Bluetooth module. I need to send the results of the heart rate via Bluetooth to my android. I have the code done for the heart rate monitor with a warning system but cant figure out how to write the code to send the heart rate results through the Bluetooth module. Any help would be much appreciated. Here is the code I am using so far.
#include "Wire.h"
#include <LiquidCrystal.h>
#define HRMI_I2C_ADDR      127
#define HRMI_HR_ALG        1   // 1= average sample, 0 = raw sample
#define redLedPin 10
#define speaker 9
LiquidCrystal lcd(A0, 13, 12, 11, 10, 9);
void setup(){
  setupHeartMonitor(HRMI_HR_ALG);
 lcd.begin(16, 2);
 lcd.setCursor(0,0);
 lcd.print("Heart Rate Test");
 lcd.setCursor(0,1);
 lcd.print("Check Heart Rate");
 pinMode(redLedPin, OUTPUT);
 pinMode(speaker, OUTPUT);
 digitalWrite(redLedPin, HIGH);
void loop(){
  int heartRate = getHeartRate();
  Serial.println(heartRate);
  delay(1000); //just here to slow down the checking to once a second
 if(getHeartRate()==0){
   lcd.setCursor(0,0);
   lcd.setCursor(0,1);
 else if ((getHeartRate() < 130)&&(getHeartRate() > 41)){
   lcd.clear();
   lcd.setCursor(0,0);
   lcd.print("Regular Heart Rate");
 else{
   lcd.clear();
   lcd.setCursor(0,0);
   lcd.print("Warning! Warning!");
   lcd.setCursor(0,1);
   lcd.print("Irregular Heart Rate");
   digitalWrite(redLedPin, HIGH);   // turn the LED on (HIGH is the voltage level)
   delay(200);               // wait for a second
   digitalWrite(redLedPin, LOW);    // turn the LED off by making the voltage LOW
   analogWrite(speaker,250);
   delay(200);
   digitalWrite(speaker, LOW);
   delay(200);
   lcd.clear();
void setupHeartMonitor(int type){
  //setup the heartrate monitor
  Wire.begin();
  writeRegister(HRMI_I2C_ADDR, 0x53, type); // Configure the HRMI with the requested algorithm mode
int getHeartRate(){
  //get and return heart rate
  //returns 0 if we couldnt get the heart rate
  byte i2cRspArray[3]; // I2C response array
  i2cRspArray[2] = 0;
  writeRegister(HRMI_I2C_ADDR,  0x47, 0x1); // Request a set of heart rate values
  if (hrmiGetData(127, 3, i2cRspArray)) {
    return i2cRspArray[2];
  else{
    return 0;
void writeRegister(int deviceAddress, byte address, byte val) {
  //I2C command to send data to a specific address on the device
  Wire.beginTransmission(deviceAddress); // start transmission to device
  Wire.write(address);       // send register address
  Wire.write(val);         // send value to write
  Wire.endTransmission();     // end transmission
boolean hrmiGetData(byte addr, byte numBytes, byte* dataArray){
  //Get data from heart rate monitor and fill dataArray byte with responce
  //Returns true if it was able to get it, false if not
  Wire.requestFrom(addr, numBytes);
  if (Wire.available()) {
    for (int i=0; i<numBytes; i++){
      dataArray[i] = Wire.read();
    return true;
  else{
    return false;
Thanks.
You don't intend to tell us:
  1. how the bluetooth device is connected to the Arduino
  2. whether you know that the device pairs with the droid
  3. whether you have any communication between the droid and the bluetooth device/Arduino
And yet you want us to tell you how to complete your project. I'm afraid you've hooked the cart on the wrong end of the horse.
