Arduino Boards connecting but nothing happening
Hi, A little help would be greatly appreciated!
Me and my partner are completing a group project and we are just a little stuck.
The first Arduino we have contains a keypad and LCD I2C 4 pin display. We are inputing a password and then a drawer number into the first Arduino where it should send this data to the the second Arduino where it should receive the drawer number and open the corresponding servo motor. Also when each drawer opens it should takeaway 1 from the maximum in each drawer which we have set at 10. There are 4 servo motors (4 drawers) and there is also a LED RGB which should go green for a correct drawer number inputed and show that it is opening and then red for if an incorrect drawer number was inputted.
The Arduino's are connecting and the first Arduino is sending the data to the second Arduino but then the second one doesn't show or do anything and doesn't open any of the servo motors.
Please help!
Arduino 1 Code:
#include <Keypad.h>
#include <ArduinoBLE.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
 BLEService MeduinoService("ef96a1f0-d34b-4f33-9684-32c8effa5c05"); //Special line of bluetooth, names used even when the communication is not for drawer data, got from UUID.net
 BLEByteCharacteristic KeypadCharacteristic("57237581-3952-49ac-a5f0-cc4fb440ae07", BLEWrite); //This sets up the bluetooth, but not two way.
 BLEBoolCharacteristic ServoCharacteristic("be7ff53a-ddfb-4c4b-bde8-c8778ff03f74", BLERead);  //reads if the drawer is opened
 BLEBoolCharacteristic InterruptCharacteristic("44348dbf-eab6-43d5-a9d2-2211903ed6f0", BLEWrite);
 BLECharacteristic MedStatsCharacteristic("2858f341-1630-4324-b0ab-3b375ed77fb3", BLERead, sizeof(int)*4 );  //Allows t communicate the stats for the medicines
 BLEDevice Servo;
const byte ROWS = 4;
const byte COLS = 3;
char keys [ROWS] [COLS] = {
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
byte rowPins[ROWS] = {A6,0,1,2};
byte colPins[COLS] = {3,4,5};
Keypad ctKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
BLEDevice Meduino2;
const String vKey[4] = {"1234", "2673", "3456", "1567"};//This makes an array for the valid passwords stored in vKey.
const int numPasswords = 4; //This shows how many valid passwprds there are.
//Each password between the '' is considered one elements, hence updating the password becomes easy. Hopefully.
//char num [4]= "";
//This stores the passkeys in the variable as a string, might help with the conversion between the types.
String Password = "";
bool accessGranted = false;//Not sure what this does.
bool drawerstate = false;
volatile bool Audit = false; //This checks if the button for the Audit is pressed
const int interruptPin = A1; //this is where the pin is added
void Reset(){
  int counter = 0;
  char num;
  char dKey;
  drawerstate =false;
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Enter Password.");
bool access(){
    for (int i = 0; i < numPasswords; i++) {
      if (Password.equals(vKey[0])) {
        accessGranted = true;
        return accessGranted;
      if (Password.equals(vKey[1])) {
      if (Password.equals(vKey[2])) {
      if (Password.equals(vKey[3])) {
      else{
void handleAudit(){
 MedStatsCharacteristic.setValue("1");
 //MedStatsCharacteristic.notify();
int counter = 0;
bool drawer(){
   while (counter<3){
   lcd.clear();
   lcd.print("Enter drawer no.");
   char dKey = ctKeypad.getKey();
        if(dKey!= NO_KEY){
          lcd.print(dKey);
           if (dKey=='1'|| dKey == '2' || dKey == '3'|| dKey=='4'){
            uint8_t drawerNum = dKey - '0';
            Serial.println("Key detected.");
            Serial.println(drawerNum);
             // This converts the character to ASCII units, as it is stored
            KeypadCharacteristic.setValue(drawerNum);
            Serial.println("dKey sent");
            //KeypadCharacteristic.notify();
          if(ServoCharacteristic.valueUpdated()){
            ServoCharacteristic.read();
            bool DrawerStat = ServoCharacteristic.read();
          if(DrawerStat==true) {
            drawerstate = true;
            Serial.println("1");
           lcd.clear();
           lcd.setCursor(0,1);
           lcd.print("Drawer ");
           lcd.print(dKey);
           lcd.print(" opened.");
           delay(9600);
           counter+=2;
           Reset();
       } else if (DrawerStat==false) {
        lcd.clear();
        lcd.print("Failed");
        Reset();
      }}} else {
         lcd.clear();
         lcd.setCursor(0,0);
         lcd.print("Not Valid.Re-enter.");
         delay(250);
         lcd.clear();
         drawerstate =false;
         counter++;
       //Want to make this a counter, more that three wrong tries and the system resets. Not sure if it's worth. Check with Gabrielle.
  return drawerstate;
  BLE.begin();
  BLE.setLocalName("Meduino1");
  BLE.setAdvertisedService(MeduinoService);
  MeduinoService.addCharacteristic(KeypadCharacteristic);
  MeduinoService.addCharacteristic(ServoCharacteristic);
  MeduinoService.addCharacteristic( MedStatsCharacteristic);
  MeduinoService.addCharacteristic(InterruptCharacteristic);
 BLE.addService(MeduinoService);
  BLE.advertise();
  Serial.println("Bluetooth on.");
  Serial.println("Detecting 2nd Arduino.");
  BLE.scan();
  pinMode(interruptPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin), handleAudit, FALLING);
  ctKeypad.setDebounceTime(200);//This was added because there was trouble in sensing the keys pressed.
  lcd.init();
  lcd.backlight();
  lcd.clear();
  lcd.setCursor(0,0);
  // put your main code here, to run repeatedly
  BLE.poll();
  BLEDevice Meduino2 =BLE.central();
 if (!Meduino2) {
    Serial.println("2nd Meduino not connected.");
    //delay(1000);
  while (Meduino2.connected()) {
    Serial.println("Connected");
    char num = ctKeypad.getKey();
    if (num != NO_KEY){
    if(Password.length()<4){
      Password += num;
       lcd.setCursor(0,1);
       lcd.print(num);
    delay(50);
    if( Password.length()==4){
      access();
      if (access()== true){//This should be that it checks if the variable access is true and then perform the next operations
       lcd.setCursor(0,1);
       //lcd.print("Access Granted");
       delay(150);
       Serial.println("Access Granted");
       lcd.clear();
       lcd.setCursor(0,0);
      drawer();
      if (drawer()==true){
        lcd.setCursor(0,0);
       else if(access()==0) {
      lcd.clear();
      lcd.setCursor(0,1);
      lcd.print("Access Denied");
      Serial.println("Access Denied");
      delay(250);
      Reset();
Arduino 2 code:
#include <Servo.h>
const int greenPin = 7;
const int redPin = 8;
unsigned long lastPrintTime = 0;  // To track the last time the print interval happened
const long printInterval = 1000;   // Interval to print debug info in milliseconds
Servo drawer1; //Declares the servo motors.
Servo drawer2;
Servo drawer3;
Servo drawer4;
//BLEDevice Meduino1;
BLECharacteristic KeypadCharacteristic;
BLECharacteristic ServoCharacteristic;
BLECharacteristic InterruptCharacteristic;
BLECharacteristic MedStatsCharacteristic;
int MedicineNumber[4]={10, 10, 10, 10};
  // put your setup code here, to run once
  while (!Serial);
  if (!BLE.begin()){
  Serial.println("Meduino1 not connected");
  while(1);
Serial.println("Meduino2 scanning");
BLE.scanForName("Meduino1");
drawer1.attach(2);//The pin is defined here
drawer2.attach(3);//The pin is defined here
drawer3.attach(4);//The pin is defined here
drawer4.attach(5);//The pin is defined here
drawer1.write(0);//The servo motor will be at rest
drawer2.write(0);//The servo motor will be at rest
drawer3.write(0);//The servo motor will be at rest
drawer4.write(0);//The servo motor will be at rest
pinMode(greenPin, OUTPUT);
pinMode(redPin, OUTPUT);
digitalWrite(greenPin, LOW); // make sure both are off initially
digitalWrite(redPin, LOW);
 //      unsigned long currentMillis = millis();
  //if (currentMillis - lastPrintTime >= printInterval) {
   // lastPrintTime = currentMillis;
    //Serial.println("Loop running");
BLE.poll();
 BLEDevice peripheral = BLE.available();
if (peripheral && peripheral.localName() == "Meduino1") {
    BLE.stopScan();
    if (peripheral.connect()) {
        Serial.println("Meduino1 connected");
     if (peripheral.discoverAttributes()) {
    KeypadCharacteristic = peripheral.characteristic("57237581-3952-49ac-a5f0-cc4fb440ae07");
    ServoCharacteristic = peripheral.characteristic("be7ff53a-ddfb-4c4b-bde8-c8778ff03f74");
    MedStatsCharacteristic = peripheral.characteristic("2858f341-1630-4324-b0ab-3b375ed77fb3");
    InterruptCharacteristic = peripheral.characteristic("44348dbf-eab6-43d5-a9d2-2211903ed6f0");
           if (!KeypadCharacteristic || !ServoCharacteristic || !MedStatsCharacteristic || !InterruptCharacteristic) {
            Serial.println("Error: One or more characteristics not found.");
            peripheral.disconnect();
            Serial.println("Characteristics discovered.");
        Serial.println("Failed to connect to Meduino1.");
        BLE.scanForName("Meduino1"); // Try reconnecting by scanning again
// Turn off both LEDs before decision
if (peripheral.connected()) {
  Serial.println("Bluetooth connection check.");
  if (KeypadCharacteristic.canRead()) {
    Serial.println("Keypad characteristic can definetely read. ");
    //if (KeypadCharacteristic.valueUpdated()) {  // Check if the value is updated
      uint8_t dKey1 = 0;
      BLE.poll();
      int dKey= KeypadCharacteristic.readValue(dKey1);  // Read the value
      Serial.println(dKey);
      // Check the received keypad value
      if (dKey != 0) {
        Serial.print("Keypad value: ");
        if (dKey == 1) {
          Serial.print("1 received from Keypad");
          digitalWrite(greenPin, HIGH);
          drawer1.write(90);
          bool drawerPosition = true;
          ServoCharacteristic.writeValue((uint8_t)drawerPosition);
          MedicineNumber[0]--;
          delay(9600);
          drawer1.write(0);
          drawerPosition = false;
          delay(2000);
        } else if (dKey == 2) {
          Serial.print("2 received from Keypad");
          drawer2.write(90);
          MedicineNumber[1]--;
          delay(9600);
          drawer2.write(0);
          delay(2000);
        } else if (dKey == 3) {
          Serial.println("3 received from Keypad");
          drawer3.write(90);
          MedicineNumber[2]--;
          delay(9600);
          drawer3.write(0);
          delay(2000);
        } else if (dKey == 4) {
          Serial.println("4 received from Keypad");
          drawer4.write(90);
          MedicineNumber[3]--;
          delay(9600);
          drawer4.write(0);
          delay(2000);
    digitalWrite(redPin, HIGH); // Red = invalid input
    bool drawerPosition = false;
    Serial.print("Drawer NOT opened/ value not updated ");
    delay(2000); // flash red briefly
// Print updated counts
//Serial.print("Medicine Counts: ");
// for (int i = 0; i < 4; i++) {
  // Serial.print("Drawer ");
  // Serial.print(i + 1);
  // Serial.print(": ");
  // Serial.print(MedicineNumber[i]);
  // Serial.print("  ");
Hi @lottienorm12,
welcome to the arduino-forum.
Well done to post your code as a code-section in you very first posting.
What exact type of arduino microcontroller are you using?
Please post the serial output of both arduinos.
Seeing the serial printing will help a lot to analyse what your code is really doing.
Did you write this code straight forward to this level? Well if you have you would be a pretty advanced software-developper.
So my guess is the code is either taken from a ready to use project you found online or the code is written by an AI.
You should do some pre-testing with small test codes if the servos can be conrolled by the second arduino.
Also add a hand drawn schematic that shows all important details.
Important are each and every wire. Do you use a extra power-supply to power the servos?
I am not too familiar with the BLE stuff, but purely from a coding perspective, as I understand it, the variable dKey1 is the variable into which the value of the key pressed is being read, so presumably this is the variable you should be checking for the value of the returned key, rather than dKey. I think 'dKey' holds the number of bytes read, although if this is zero, that's not good either....
Hopefully someone more familiar will be able to delve into the reasons for that.
Sorry... I did not read the name and I responded to @BitSeeker... my mistake.
We are using the MKR 1000 Wifi Arduino.
I'm not sure where to find the serial output from the Arduinos. Where can I find it?
We have pieced it together from our university classes, teachers help and then when we're stuck asked AI but most is done ourselves.
The servo works with the general code but when connecting them it doesn't receive the drawer number from the first Arduino so therefore does not unlock. But if inputting the drawer number in the serial monitor for the second Arduino the servos work.
We do have an extra x4 AA battery pack, but the servos were working with just 5V USB connection.
Thank you! Will have a look at that part and change it and will see whether that works now!
Your code has quite a lot of Serial.print statements. This is what gets printed to the serial monitor.
AI is pretty bad at writing code. Especially if your prompt is not super-precise.
But the AI can help you explain how to use the serial monitor
The arduino-IDE has a serial monitor.
Though in the Arduino IDE 2.X the serial monitors functionality is crippeld almost not usable.
@ptillisch: anything new about improving the serial monitor in IDE 2.X ?
You could use a different serial terminal software or you install Arduino IDE 1.8.19 which has a very good serial monitor functionality.
