After reinstalling W10 64b and installing Arduino IDE v1.8.13 I discovered that I do not get anymore the extensive list of exported compiled binaries as before.
I did not make a backup of the platform.txt file, so back here for advise please?
You don't mention to which boards this applies, your output shows Nano.
There has never been additional files for the standard AVR boards. @DrAzzy's ATtiny core did produce e.g. a list file and maybe other cores do as well.
I copied the relevant lines in his/her platform.txt from that into Arduino's AVR core.
Binaries in Arduino refer to the compiled output files generated from your sketches. These files typically include formats such as .bin and .hex. They are essential for uploading your code to Arduino boards.
Where Are Binaries Stored?
By default, the Arduino IDE stores these binaries in a temporary directory. The exact location can vary based on your operating system:
Windows: Binaries are often found in a hidden directory under `C:\Users\\AppData\Local\Temp\build*
Mac/Linux: Binaries are usually stored in a temporary folder like /tmp.
Configuring Binary Storage Location
You can change where the Arduino IDE saves these binaries by modifying the IDE's configuration files. Here’s how to do it:
Locate the Configuration File:
For Arduino IDE 1.x, find preferences.txt in C:\Users\<YourUsername>\AppData\Roaming\Arduino.
For Arduino IDE 2.x, edit the arduino-cli.yaml file located at C:\Users\<YourUsername>\.arduinoIDE.
Edit the File:
Add or modify the line to set your desired build path:
For preferences.txt: build.path=C:\Documents\Arduino\Build
For arduino-cli.yaml: sketch: always_export_binaries: true
Save and Restart the IDE: After making changes, save the file and restart the Arduino IDE to apply the new settings.
Benefits of Custom Binary Storage
Easier Access: Keeping binaries in a specific folder makes it easier to manage and track them, especially if you use version control systems like Git.
Organization: It helps maintain a clean workspace by preventing clutter in temporary directories.”
I’m guessing as you put new IDE code in place it might now just be putting new files in a temp location. Aren’t the others where you last put them?
You subject mentions 1.8.6 and your post 1.8.13. Is there any particular reason you have not installed 1.8.19? Or even the much newer 2.3.7?
I don't know whether back in 1.8.6 you got those various permutations or not, but the exact binaries produced do depend on which board platform package has been selected.
