arno64
November 30, 2024, 9:45am
1
Hello,
trying to program an Arduino ESP32 Nano with arduino-cli and have problems with an library.
In the IDE 2.3.3 it is possible to switch in the tools menu to Pin Numbering: By GPIO number,
this solves my problem.
How can I achieve this with arduino-cli?
Hi @arno64 . When using Arduino CLI , custom board options like the "Pin Numbering " option of the Nano ESP32 board are set via --board-options flags added to the arduino-cli commands.
The format of the flag is like this:
--board-options "<menu ID>=<option ID>"
(where <menu ID> and <option ID> are placeholders for the custom board options menu and menu option you are setting)
You can learn all the available menu IDs and option IDs for a given board by running the following arduino-cli command :
arduino-cli board details --fqbn <FQBN>
(where <FQBN> is replaced by the fully qualified board name of the board you are using)
For example:
$ arduino-cli board details --fqbn arduino:esp32:nano_nora
Board name: Arduino Nano ESP32
FQBN: arduino:esp32:nano_nora
Board version: 2.0.18-arduino.5
Official Arduino board: ✔
Identification properties: pid=0x0070
vid=0x2341
Package name: arduino
Package maintainer: Arduino
Package URL: https://downloads.arduino.cc/packages/package_index.tar.bz2
Package website: http://www.arduino.cc/
Package online help: http://www.arduino.cc/en/Reference/HomePage
Platform name: Arduino ESP32 Boards
Platform category: Arduino
Platform architecture: esp32
Platform URL: https://downloads.arduino.cc/cores/staging/esp32-v2.0.17-arduino.5.zip
Platform file name: esp32-v2.0.17-arduino.5.zip
Platform size (bytes): 88321110
Platform checksum: SHA-256:03596062ab1745bf7847d09900e2aebfc1f49cf123d47ba8a57d652e110cda5c
Required tool: arduino:dfu-util 0.11.0-arduino5
Required tool: esp32:esptool_py 4.5.1
Required tool: esp32:mklittlefs 3.0.0-gnu12-dc7f933
Required tool: esp32:mkspiffs 0.2.3
Required tool: esp32:openocd-esp32 v0.12.0-esp32-20230921
Required tool: esp32:s3-gcc 2021r2-p5
Required tool: esp32:xtensa-esp-elf-gdb 11.2_20220823
Option: USB Mode USBMode
Normal mode (TinyUSB) ✔ USBMode=default
Debug mode (Hardware CDC) USBMode=hwcdc
Option: Partition Scheme PartitionScheme
With FAT partition (default) ✔ PartitionScheme=default
With SPIFFS partition (advanced) PartitionScheme=spiffs
Option: Pin Numbering PinNumbers
By Arduino pin (default) ✔ PinNumbers=default
By GPIO number (legacy) PinNumbers=byGPIONumber
Programmers: ID Name
esptool Esptool
Here we can see that the ID for the "Pin Numbering " menu is PinNumbers and the ID for the "By GPIO number (legacy) " option is byGPIONumber.
So, if you wanted to compile a sketch with this custom board option, you would use the following command:
arduino-cli compile --fqbn arduino:esp32:nano_nora --board-options "PinNumbers=byGPIONumber"
ⓘ You can add multiple --board-options flags to an arduino-cli command if you want to set multiple custom board options menus.
arno64
November 30, 2024, 10:39am
3
Thank you so much ptillisch, this was very helpful. I was not able to find this information by
myself.. sorry..
Everything is running now. I`m happy..
You are welcome. I'm glad it is working now.
Regards, Per
