30 Minutes ago none of my sketches would compile. I just got a message saying "Please be patient" and then nothing. A bit later I got a message saying that "we are having problems compiling" then a bit later everything worked and I compiled and loaded my sketch OK. So then I made a couple of changes but when compiling I am getting a console message saying completed in red but above it a message saying "compilation error" no errors logged on the console. I have tried different computers and browsers but all the same.
I also had the same thing! I removed the device from the list and reconfigured it from scratch. After that, everything worked correctly.
Szpieg. Thanks for replying. I have actually just put a BLINK sketch in with a new device etc. all done from scratch and it still fails. I think that it could be a problem in the cloud server. It is a real pain as I am in the middle of doing my first complex project and this has stopped everything dead.
I'm having the same problem, in the console there's no errors except "completed", but verification fails. This is with a program that I had running last night. I'm inclined to think this is a problem on the Cloud side as I'm seeing other posts now with the same problem.
Cloud editor is still messed up. Getting the same error here.
I have great problems too.
I tried to set up new devs, tried old ones, also tried to verify the existing code on online devs, but the only thing that happens is "Console ! Error Verifying" followed by the file name, then "completed".
Tried different computers on different networks, all the same.
A bug at the Arduino site?
It is now 10:30 Wednesday 26th. I tried again and it all now works. So Arduino have fixed the problem their end.
Still have compile issues and impossible to connect to cloud even when compiled worked once this morning, with the same code. Come on Arduino, you are loosing credibility here.
Arduino identified and solved the problem. Now the compile through Cloud Editor works as expected. Sorry for the issue and thank you for your understanding.
You can check the Arduino Status Page, reporting the incident: https://status.arduino.cc/
