Arduino Compilation error: Error: 2 UNKNOWN: no FQBN provided
I am trying to upload code to my Arduino Uno board, however in the Arduino itself I am getting the error Compilation error: Error: 2 UNKNOWN: no FQBN provided.
The code is below. This is code took from the internet which seemed to have worked for many other people.
I tried to verify the code from the examples in the Arduino and I am getting the same error code.
I assume it is nothing to do with the code, rather the Arduino software itself.
if anyone can help I would appreciate it.
Thanks in advance.
[code]
  int ledPin = 13;
int pirPin = 9;
int val = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(pirPin, INPUT);
  val = digitalRead(pirPin);
  digitalWrite(ledPin, val);
if (val ==1)
  digitalWrite(ledPin, LOW);
}// put your setup code here, to run once:
[/code]
Hi @kajraj14. This error occurs when you have not selected a board. Unlike the classic Arduino IDE, the Arduino IDE 2.x does not have any boards selected on startup. There is also currently a bug that causes the board selection to be forgotten every time you open a new sketch.
So you only need to select Tools > Board > Arduino AVR Boards > Arduino Uno. After that, you'll be able to compile and upload.
Please let me know if you have any problems after doing that.
Hi thanks for your reply, that hasn't resolved it, unfortunately.
now I am getting an error stated below.
i am new to arduino, so could be something silly.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Pir_sensor_v1:3:13: error: expected ')' before ';' token
int led = 13;
C:\Users\user\Documents\Arduino\Pir_sensor_v1\Pir_sensor_v1.ino: In function 'void setup()':
Pir_sensor_v1:12:10: error: 'led' was not declared in this scope
pinMode(led, OUTPUT);
Pir_sensor_v1:14:2: error: 'serial' was not declared in this scope
serial.begin(9600) // put youPr setup code here, to run once:
C:\Users\user\Documents\Arduino\Pir_sensor_v1\Pir_sensor_v1.ino:14:2: note: suggested alternative: 'Serial'
Serial
C:\Users\user\Documents\Arduino\Pir_sensor_v1\Pir_sensor_v1.ino: In function 'void loop()':
Pir_sensor_v1:19:11: error: 'DigitalRead' was not declared in this scope
value = DigitalRead(pin)
C:\Users\user\Documents\Arduino\Pir_sensor_v1\Pir_sensor_v1.ino:19:11: note: suggested alternative: 'digitalRead'
digitalRead
Pir_sensor_v1:28:2: error: 'else' without a previous 'if'
}else
Pir_sensor_v1:30:14: error: 'led' was not declared in this scope
digitalWrite(led, LOW);
Pir_sensor_v1:33:3: error: 'serial' was not declared in this scope
serial.printIn ("Motion Ended!");
C:\Users\user\Documents\Arduino\Pir_sensor_v1\Pir_sensor_v1.ino:33:3: note: suggested alternative: 'Serial'
Serial
Pir_sensor_v1:34:14: error: 'lOW' was not declared in this scope
pirState = lOW;
C:\Users\user\Documents\Arduino\Pir_sensor_v1\Pir_sensor_v1.ino:34:14: note: suggested alternative: 'LOW'
pirState = lOW;
LOW
C:\Users\user\Documents\Arduino\Pir_sensor_v1\Pir_sensor_v1.ino: At global scope:
Pir_sensor_v1:38:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
This has indeed resolved the initial error. Now you have the bugs in your sketch.
You are experiencing the common situation where there are multiple problems all stacked on top of each other. In this case, fixing the first problem only exposes the second one, but that's still progress! Just keep working your way through them and you'll be sure to achieve success with your goals.
  int ledPin = 13;
int pirPin = 9;
int val = 0;
that second "void setup ()" should not be there.
Or the first "void setup (){" shouldn't be there.
Probably the first one should go.
