arduino compiler done but not compile my file
arduino compiler say done compile but my code is error what can i do?
thanks
plz reply
@microjack64's arduino error.png:
That is strange. Does compilation pass if you try again?
(deleted)
yes i am compiling again and again but error is coming there Done compile
(deleted)
Seems strange , but I guess you do know what is wrong with the sketch ?
As said you need to post with code tags so we can see it properly .
Missing ; }
Please do this:
  • (In the Arduino IDE) click File > Preferences
  • Check the box next to "Show verbose output during: > compilation
  • Click "OK"
  • Sketch > Verify/Compile
  • After the compilation fails, click on the black console pane at the bottom of the Arduino IDE window.
  • Press "Ctrl + A". This will select all the text.
  • Press "Ctrl + C". This will copy the selected text to the clipboard.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the compilation output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
If the length of the output exceeds the forum's 9000 character limit, save it in a .txt file and post it here as an attachment. If you click the "Reply" button you'll see the "Attachments and other options" link that will allow you to make the attachment.
thanks for reply
i also installed new software but still the file is not compiled
not a code issue
(deleted)
here is the simple code
there is no issue in code
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
pert:
Please do this:
  • Click "OK"
The code from reply #9 compiles fine.
microjack64:
Please explain what you mean by that. What new software? Is it possible that you confuse "compiled" with "uploaded"?
