Arduino doesn't recognise second sensor
Hello,
I am building a water tank sensor (based on this project: Wireless Water-Tank Level Meter with Alarm | Arduino Project Hub but without some of the features.)
The project uses a ultra sonic sensor AJ-SRO4M and a radio transmitter. The receiving unit has an lcd screen which displays the level of water in the tank. The project worked well with 1 sensor. However, I have 2 water tanks and I wanted to add a second sensor.
To test the transmitter, the readings were displayed in a serial monitor. The first sensor works fine but the second isn't reading. The results show 0cm. I already bought another sensor. I tested this new sensor, using the single sensor code and it worked.
I am using a atmega328. code is below:
/* Water tank sensor transmitter*//
#include <SoftwareSerial.h>
SoftwareSerial HC12(4, 5);
int POWER = 6;
long dist_1 = 0;
long dist_2a = 0;
long dist_2 = 0;
int TRIG1 = 2;
int ECHO1 = 3;
int TRIG2 = 8;
int ECHO2 = 7;
HC12.begin(9600);
pinMode(TRIG1, OUTPUT);
digitalWrite(TRIG1, LOW);
pinMode(ECHO1, INPUT);
pinMode(POWER, OUTPUT);
digitalWrite(POWER , 1);
pinMode(TRIG2, OUTPUT);
digitalWrite(TRIG2, LOW);
pinMode(ECHO2, INPUT);
delayMicroseconds(5);
digitalWrite(TRIG1, HIGH);
delayMicroseconds(10);
digitalWrite(TRIG2, HIGH);
dist_1 = (pulseIn(ECHO1, HIGH))*0.034/2;
dist_2 = (pulseIn(ECHO2, HIGH))*0.034/2;
dist_2a = dist_2 * -1;
HC12.write(dist_1);
HC12.write(dist_2a);
Serial.print("TANK 1 ");
Serial.print(dist_1);
Serial.print("cm");
Serial.print("TANK 2 ");
Serial.print(dist_2);
Serial.print("cm");
HC12 is the radio transmitter. dist_2a is my way to distinguish the 2 readings in the receiving unit. The reading for tank 2 will be negative. (I am a very basic coder...)
Maybe there is an issue with using pins 7 and 8 for the trig and echo?
Any help would be appreciated.
Move the pulse measurement to right after the trigger. Where you have it the pulse may be gone by the time you try to measure it.
Thanks,
That solved it!
