Arduino DUE, strano comportamento
Salve, ho ripreso in mano un Arduino DUE che avevo in casa da diversi anni, tutto sembra funzionare a dovere, viene rilevato dal sistema, carica il programma senza problemi ma e' come non non esegue il programma.
Ho il led "L" perennemente acceso, ho provato a caricare questo classico esempio del blink del led:
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  digitalWrite(LED_BUILTIN, LOW);
e lo carica senza problemi come vedete:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\king\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\king\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\king\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x_dbg -vid-pid=2341_003D -ide-version=10819 -build-path C:\Users\king\AppData\Local\Temp\arduino_build_259621 -warnings=default -build-cache C:\Users\king\AppData\Local\Temp\arduino_cache_869917 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\king\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.bossac-1.6.1-arduino.path=C:\Users\king\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\king\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\king\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -verbose C:\Users\king\Desktop\readan\readan.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\king\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\king\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\king\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x_dbg -vid-pid=2341_003D -ide-version=10819 -build-path C:\Users\king\AppData\Local\Temp\arduino_build_259621 -warnings=default -build-cache C:\Users\king\AppData\Local\Temp\arduino_cache_869917 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\king\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.bossac-1.6.1-arduino.path=C:\Users\king\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\king\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.arm-none-eabi-gcc-4.8.3-2014q1.path=C:\Users\king\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -verbose C:\Users\king\Desktop\readan\readan.ino
Using board 'arduino_due_x_dbg' from platform in folder: C:\Users\king\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12
Using core 'arduino' from platform in folder: C:\Users\king\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12
Detecting libraries used...
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\sketch\\readan.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\sketch\\readan.ino.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sto compilando lo sketch...
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\sketch\\readan.ino.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\sketch\\readan.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x\\variant.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\variant.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -x assembler-with-cpp -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\wiring_pulse_asm.S" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring_pulse_asm.S.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\WInterrupts.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\WInterrupts.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\hooks.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\hooks.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring_analog.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\cortex_handlers.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\cortex_handlers.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\syscalls_sam3.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\syscalls_sam3.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\wiring.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\itoa.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\itoa.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\iar_calls_sam3.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\iar_calls_sam3.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring_digital.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring_shift.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -c -g -Os -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -Dprintf=iprintf -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\avr\\dtostrf.c" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\avr\\dtostrf.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\IPAddress.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\IPAddress.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\Print.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\Print.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\Reset.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\Reset.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\USARTClass.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\USARTClass.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\Stream.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\Stream.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\WMath.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\RingBuffer.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\RingBuffer.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\UARTClass.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\UARTClass.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\WString.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\WString.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\abi.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\abi.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\main.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\main.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\new.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\new.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\watchdog.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\watchdog.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\wiring_pulse.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring_pulse.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\USB\\CDC.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\USB\\CDC.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\USB\\PluggableUSB.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\USB\\PluggableUSB.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10819 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino Due\"" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/libsam" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/CMSIS/Include/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\system/CMSIS/Device/ATMEL/" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino" "-IC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\cores\\arduino\\USB\\USBCore.cpp" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\USB\\USBCore.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring_pulse_asm.S.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\WInterrupts.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\avr\\dtostrf.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\cortex_handlers.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\hooks.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\iar_calls_sam3.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\itoa.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\syscalls_sam3.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring_analog.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring_digital.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring_shift.c.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\IPAddress.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\Print.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\Reset.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\RingBuffer.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\Stream.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\UARTClass.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\USARTClass.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\USB\\CDC.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\USB\\PluggableUSB.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\USB\\USBCore.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\WMath.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\WString.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\abi.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\main.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\new.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\watchdog.cpp.o"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-ar" rcs "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\core.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\wiring_pulse.cpp.o"
Archivio il core (caching) compilato in: C:\Users\king\AppData\Local\Temp\arduino_cache_869917\core\core_arduino_sam_arduino_due_x_dbg_84cb3bec87d9f07fe2e26048fb7c393c.a
Linking everything together...
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-gcc" -mcpu=cortex-m3 -mthumb -Os -Wl,--gc-sections "-TC:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x/linker_scripts/gcc/flash.ld" "-Wl,-Map,C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621/readan.ino.map" -o "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621/readan.ino.elf" "-LC:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621" -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--start-group -u _sbrk -u link -u _close -u _fstat -u _isatty -u _lseek -u _read -u _write -u _exit -u kill -u _getpid "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\sketch\\readan.ino.cpp.o" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621\\core\\variant.cpp.o" "C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\sam\\1.6.12\\variants\\arduino_due_x/libsam_sam3x8e_gcc_rel.a" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621/core\\core.a" -Wl,--end-group -lm -lgcc
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621/readan.ino.elf" "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621/readan.ino.bin"
"C:\\Users\\king\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\4.8.3-2014q1/bin/arm-none-eabi-size" -A "C:\\Users\\king\\AppData\\Local\\Temp\\arduino_build_259621/readan.ino.elf"
Lo sketch usa 10684 byte (2%) dello spazio disponibile per i programmi. Il massimo è 524288 byte.
Forzo il reset aprendo e chiudendo a 1200bps la porta COM5
C:\Users\king\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino/bossac.exe -i -d --port=COM5 -U false -e -w -v -b C:\Users\king\AppData\Local\Temp\arduino_build_259621/readan.ino.bin -R
Send auto-baud
Set binary mode
readWord(addr=0)=0x20001000
readWord(addr=0xe000ed00)=0x412fc230
readWord(addr=0x400e0740)=0
readWord(addr=0x400e0940)=0x285e0a60
version()=v1.1 Dec 15 2010 19:25:04
chipId=0x285e0a60
Connected at 115200 baud
Atmel SMART device 0x285e0a60 found
write(addr=0x20001000,size=0x34)
writeWord(addr=0x20001030,value=0x40)
writeWord(addr=0x20001020,value=0x20010000)
writeWord(addr=0x400e0a00,value=0x600)
writeWord(addr=0x400e0c00,value=0x600)
Device       : ATSAM3X8
Chip ID      : 285e0a60
Version      : v1.1 Dec 15 2010 19:25:04
Address      : 524288
Pages        : 2048
Page Size    : 256 bytes
Total Size   : 512KB
Planes       : 2
Lock Regions : 32
Locked       : readWord(addr=0x400e0a08)=0x1
readWord(addr=0x400e0c08)=0x1
writeWord(addr=0x400e0a04,value=0x5a00000a)
readWord(addr=0x400e0a0c)=0
writeWord(addr=0x400e0c04,value=0x5a00000a)
readWord(addr=0x400e0c0c)=0
none
writeWord(addr=0x400e0a04,value=0x5a00000d)
Security     : false
Boot Flash   : false
Erase flash
writeWord(addr=0x400e0a04,value=0x5a000005)
writeWord(addr=0x400e0c04,value=0x5a000005)
done in 0.038 seconds
Write 11864 bytes to flash (47 pages)
[                              ] 0% (0/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x80000)
writeWord(addr=0x2000102c,value=0x20002000)
writeWord(addr=0x20001024,value=0x20001001)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000001)
write(addr=0x20002100,size=0x100)
writeWord(addr=0x20001028,value=0x80100)
writeWord(addr=0x2000102c,value=0x20002100)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000101)
writeWord(addr=0x20001028,value=0x80200)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000201)
writeWord(addr=0x20001028,value=0x80300)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000301)
[==                            ] 8% (4/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x80400)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000401)
writeWord(addr=0x20001028,value=0x80500)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000501)
writeWord(addr=0x20001028,value=0x80600)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000601)
writeWord(addr=0x20001028,value=0x80700)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000701)
[=====                         ] 17% (8/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x80800)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000801)
writeWord(addr=0x20001028,value=0x80900)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000901)
writeWord(addr=0x20001028,value=0x80a00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000a01)
writeWord(addr=0x20001028,value=0x80b00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000b01)
[=======                       ] 25% (12/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x80c00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000c01)
writeWord(addr=0x20001028,value=0x80d00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000d01)
writeWord(addr=0x20001028,value=0x80e00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000e01)
writeWord(addr=0x20001028,value=0x80f00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a000f01)
[==========                    ] 34% (16/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x81000)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001001)
writeWord(addr=0x20001028,value=0x81100)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001101)
writeWord(addr=0x20001028,value=0x81200)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001201)
writeWord(addr=0x20001028,value=0x81300)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001301)
[============                  ] 42% (20/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x81400)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001401)
writeWord(addr=0x20001028,value=0x81500)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001501)
writeWord(addr=0x20001028,value=0x81600)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001601)
writeWord(addr=0x20001028,value=0x81700)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001701)
[===============               ] 51% (24/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x81800)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001801)
writeWord(addr=0x20001028,value=0x81900)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001901)
writeWord(addr=0x20001028,value=0x81a00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001a01)
writeWord(addr=0x20001028,value=0x81b00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001b01)
[=================             ] 59% (28/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x81c00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001c01)
writeWord(addr=0x20001028,value=0x81d00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001d01)
writeWord(addr=0x20001028,value=0x81e00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001e01)
writeWord(addr=0x20001028,value=0x81f00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a001f01)
[====================          ] 68% (32/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x82000)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002001)
writeWord(addr=0x20001028,value=0x82100)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002101)
writeWord(addr=0x20001028,value=0x82200)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002201)
writeWord(addr=0x20001028,value=0x82300)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002301)
[======================        ] 76% (36/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x82400)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002401)
writeWord(addr=0x20001028,value=0x82500)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002501)
writeWord(addr=0x20001028,value=0x82600)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002601)
writeWord(addr=0x20001028,value=0x82700)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002701)
[=========================     ] 85% (40/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x82800)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002801)
writeWord(addr=0x20001028,value=0x82900)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002901)
writeWord(addr=0x20001028,value=0x82a00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002a01)
writeWord(addr=0x20001028,value=0x82b00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002b01)
[============================  ] 93% (44/47 pages)write(addr=0x20002000,size=0x100)
writeWord(addr=0x20001028,value=0x82c00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002c01)
writeWord(addr=0x20001028,value=0x82d00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002d01)
write(addr=0x20002000,size=0x58)
writeWord(addr=0x20001028,value=0x82e00)
go(addr=0x20001020)
writeWord(addr=0x400e0a04,value=0x5a002e01)
[==============================] 100% (47/47 pages)
done in 2.427 seconds
Verify 11864 bytes of flash
[                              ] 0% (0/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x80000)
go(addr=0x20001020)
read(addr=0x20002100,size=0x100)
writeWord(addr=0x2000102c,value=0x80100)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80200)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80300)
go(addr=0x20001020)
[==                            ] 8% (4/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x80400)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80500)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80600)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80700)
go(addr=0x20001020)
[=====                         ] 17% (8/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x80800)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80900)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80a00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80b00)
go(addr=0x20001020)
[=======                       ] 25% (12/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x80c00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80d00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80e00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x80f00)
go(addr=0x20001020)
[==========                    ] 34% (16/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x81000)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81100)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81200)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81300)
go(addr=0x20001020)
[============                  ] 42% (20/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x81400)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81500)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81600)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81700)
go(addr=0x20001020)
[===============               ] 51% (24/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x81800)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81900)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81a00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81b00)
go(addr=0x20001020)
[=================             ] 59% (28/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x81c00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81d00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81e00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x81f00)
go(addr=0x20001020)
[====================          ] 68% (32/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x82000)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82100)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82200)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82300)
go(addr=0x20001020)
[======================        ] 76% (36/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x82400)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82500)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82600)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82700)
go(addr=0x20001020)
[=========================     ] 85% (40/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x82800)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82900)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82a00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82b00)
go(addr=0x20001020)
[============================  ] 93% (44/47 pages)writeWord(addr=0x20001028,value=0x20002100)
writeWord(addr=0x2000102c,value=0x82c00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82d00)
go(addr=0x20001020)
writeWord(addr=0x2000102c,value=0x82e00)
go(addr=0x20001020)
Verify successful
done in 2.366 seconds
Set boot flash true
writeWord(addr=0x400e0a04,value=0x5a00010b)
CPU reset.
readWord(addr=0)=0x20088000
writeWord(addr=0x400e1a00,value=0xa500000d)
Ma il led "L" rimane comunque sempre acceso anche provando a resettare, ho provato anche con un erase e ricaricare tutto ma il problema persiste.
Possibile che si sia guastata la MCU ?
Buongiorno e benvenuto nella sezione Italiana del forum, :slight_smile:
cortesemente, come prima cosa, leggi attentamente il REGOLAMENTO di detta sezione, (... e, per evitare future possibili discussioni/incomprensioni, prestando molta attenzione al punto 15), dopo di che, come da suddetto regolamento (punto 16.7), fai la tua presentazione NELL'APPOSITA DISCUSSIONE (... quello che vedi in blu è un link, fai click su di esso per raggiungere la discussione) spiegando bene quali esperienze hai in elettronica e programmazione, affinché noi possiamo conoscere la tua esperienza ed esprimerci con termini adeguati.
Grazie,
Guglielmo
P.S.: Ti ricordo che, purtroppo, fino a quando non sarà fatta la presentazione nell’apposita discussione, nel rispetto del succitato regolamento nessuno ti risponderà (eventuali risposte o tuoi ulteriori post, verrebbero temporaneamente nascosti), quindi ti consiglio di farla al più presto. :wink:
