Ah, so what you are trying to do is use the Duemilanove as a programmer for the ESCs.
NOT trying to put a bootloader into the Duemilanove.
I didn't watch the whole video; just enough to see that MOSI, MISO, and Gnd from the Duemilanove are being conneced to the ESC.
If you are trying to download a sketch into the Duemilanove and you are getting that error:
try the Loopback test to see that your USB interface is working, you may need to install the FTDTI drivers (altho they would seem to be in place already if -0022 is working);
then try loading a simple sketch like Blink to that the '328P is working properly.
Yes you are right. When I send blink fromm 0022 everything works as it should but when I use the latest IDE 1.0.5 I get the error message. I dont know what is the difference between the 2 IDE's? Something very strange which I cant rectify. Maybe your help will be a miracle
I don't know what to offer. I have 1.0.5 on a Win7Pro laptop. I just bootloaded my Duemilanove with Uno bootloader (had to put a chip in first, it had been pulled for some other project apparently) using Atmel AVR ISP MKii.
After the bootloader, I loaded the blink sketch.
So: maybe you have an FTDI driver problem, try rolling back to an earlier version. Mine is using 2.8.30.0
Or, your bootloader is running 1 speed, and the PC is expecting a different speed. Re-bootload, select Uno as board type, and use Uno as board type for sketch downloads.
