Arduino error: expected '(' before numeric constant
Hello,
I am trying to write code so that the timing of my LED sequence changes when I change the voltage level on input A.
Can you help me get past the compiler error please?
int red = 13;
int yellow = 12;
int green = 11;
int blue = 10;
int A = 9;
int B = 8;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(red, OUTPUT);
pinMode(yellow, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
pinMode(A, INPUT);
// the loop routine runs over and over again forever:
void loop(){
digitalWrite(red, HIGH); // turn the LED on (HIGH is the voltage level)
delay(900); // wait for a second
digitalWrite(red, LOW); // turn the LED off by making the voltage LOW
delay(200);
delay(100);
{digitalWrite(yellow, HIGH);
delay(900);
digitalWrite(yellow, LOW);
delay(200);}
delay(900);
delay(200);}
{digitalWrite(green, HIGH);
delay(900);
digitalWrite(green, LOW);
delay(200);}
delay(900);
delay(200);}
{digitalWrite(blue, HIGH);
delay(900);
digitalWrite(blue, LOW);
delay(200);}
delay(900);
delay(200);}
if INPUT A = HIGH;
delay(200); // wait for a second
delay(200);
delay(200);
delay(200);
delay(200);}
delay(200);
delay(200);}
delay(200);
delay(200);}
delay(200);
delay(200);}
delay(200);
delay(200);}
delay(200);
delay(200);}}
if INPUT A = HIGH;
You are NOT programming in whatever language you are used to.
{Why} {is} {your} {code} {full} {of} {useless} {curly} {braces} {?}
if INPUT A = HIGH;
Wow. So many mistakes in 1 line
The test expression should be in brackets
What is being tested ? Is it INPUT, A or a variable named INPUT A, which has a illegal space in its name
= is for assignment, == is for comparison
If statements almost never end with a semicolon
The problems continue after the test. Should it return true, how does the compiler know which statement or statements to execute ?
PaulS:
if INPUT A = HIGH;
I am new to Arduino, can you please explain to me what my code should be if not "if INPUT A = HIGH"
Have you seen any of the many worked examples in the IDE?
AWOL:
No, are these examples on the site or in the software?
darragh_condell:
In the IDE. The thing you used to compile the code.
Under "examples"
necesito ayuda con mi codigo por favor, no compila y me da un error: expected ')' before numeric constant
exit status 1
el codigo es para ecender 2 led con control remoto infrarrojo y ajustar la luminosidad de cada led con el control,lo voy a subir a un arduino nano,ATmega168
el ide arduino es 1.8.8 en windows 10 este es mi codigo:
#include <IRremote.h>
#define white 0xF171
#define offw 0xF1B1
#define lighta 0xF129
#define lightb 0xF1A9
#define red 0xF1A1
#define offr 0xF121
#define lightA 0xF1C9
#define lightB 0xF149
#define MAX_BRIGHT 255
#define SL_BD_RT 9600
#define RECV_PIN 11
#define LED_PIN 5 //
#define LED_PIN 6 //
byte ledState;
IRrecv irrecv(RECV_PIN);
decode_results results;
boolean power_state = LOW;
void setup(){
Serial.begin(SL_BD_RT);
irrecv.enableIRIn(); //
pinMode(LED_PIN 5 ,OUTPUT);
pinMode(LED_PIN 6 ,OUTPUT); //
if (irrecv.decode(&results)) { //
switch(results.value) {
case offw:
ledState = 125;
digitalWrite(LED_PIN 5, LOW); //
case offr:
ledState = 125;
digitalWrite(LED_PIN 6, LOW); //
case white:
digitalWrite(LED_PIN 5, HIGH); //
case red:
digitalWrite(LED_PIN 6, HIGH); //
case lightb:
ledState -=10;
if (ledState > 0){
analogWrite(LED_PIN 5, ledState); //
case lightB:
ledState -=10;
if (ledState > 0){
analogWrite(LED_PIN 6, ledState); //
case lighta:
if (ledState < MAX_BRIGHT){
ledState +=10;
case lightA:
ledState +=10;
delay(200); //
irrecv.resume(); //
Eight there.
