Hello everyone
I am interested in recording voice with an Arduino Uno luckily I have done the hardware part and I am stuck in programming.
The Arduino must constantly take measurements out of the microphone with delayMicroseconds(125) -until a switch is changed - and pass the outputValue in the Openstate_record_values part and let the programm keep running.Any suggestions are more than welcome.
Thank you in advance,
Napster
#include <SD.h>
#include <LiquidCrystal.h>
// File myFile;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// These constants won't change. They're used to give names
// to the pins used:
/* sensor eading Variables */
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
const int onoffswitch = 6; // on/off switch
const int record_button = 7; // record button A2 button
const int memwrite = 10; // Analog output pin that the LED is attached to
int sensorValue = 0; // value read from the sensor
int outputValue = 0; // value output to the PWM (analog out)
//record_button == 0; //initialising push button for recording
//int record_button=A2 ;
//Controls
int count = 0; // global counter
int onoffstate = 0 ; //=0;
int recordstate = 0 ;
Serial.begin(9600); // initialize serial communications at 9600 bps:
pinMode(onoffswitch, INPUT); //use slide switch as input , pin 6
pinMode(record_button, INPUT); // use slide switch as input , pin 7
pinMode(memwrite,OUTPUT); //set to digital pin 10 as Output where the data will be saved
lcd.begin(16, 2); //initialising a 16x2 LCD
Switches();
float Switches() {
lcd.clear();
lcd.home();
onoffstate = digitalRead(onoffswitch);
/*if #1*/ if (onoffstate == HIGH){
recordstate = digitalRead(record_button);
/*if #2*/ if (recordstate == HIGH){
count = count + 1 ;
while ( count % 2 != 0 ) { //if the count is an even number then start recording
// Sensor_Reading();
Openstate_record_values();//Getting the vinput from the sensor
/*if #3*/
count = count + 1 ;
// &&&&&&&&&&&&&& add code to read-write to external memory (I will cover this part)
}//if #3 closing bracket
} //while closing bracket
} //if #2 closing bracket
else { // /*else for the if #2*/
// for(int j = 0; j < 17; j++){
lcd.clear();
lcd.home();
lcd.setCursor(10, 0);//changed from (0,0)
lcd.print("System is ON" );
lcd.setCursor(4, 1);
lcd.print("Please press button to record " ); //The device is on but not recording
lcd.scrollDisplayLeft();
delay(200);
}//else closing bracket
}//if #1 closing bracket
/*if #4*/ if (onoffstate != HIGH){
lcd.setCursor(1, 0);
lcd.print("System is OFF" );
}//if #4 closing bracket
}//Switches bracket
float Openstate_record_values() {
// int sensorValue = analogRead(analogInPin); //must be places somehwere with no delay
// int outputValue = map(sensorValue, 0, 1023, 0, 255);
lcd.clear();
lcd.home();
lcd.setCursor(0, 0);
lcd.print("Recording..." );
delay(400);
lcd.clear();
lcd.home();
lcd.print("Sensor=" );
lcd.print(sensorValue);
lcd.setCursor(0, 1);
lcd.print("Output=");
lcd.println(outputValue);
digitalWrite(memwrite, outputValue);// *************this part must be places somewhere else with no delay
float Sensor_Reading(){
delayMicroseconds(125);
