HELLO,
im using MEGA 2560. it has 5 GND pins. are they analog GND or digital GND?
Thank you,
HELLO,
Thank you,
There's no distinction. The Arduino boards don't keep a separate analog ground.
GND is just GND
all 5 are the same
But i know that there is analog grounds and digital grounds.
Yes, but on the Arduino board all grounds are connected together. Use your multimeter and confirm yourself.
You can connect analog grounds to a ground header near the analog pins if that makes you feel better.
So i can connect analog grounds and digital grounds togheter to the GND pins in the arduino?
I have 25 pins connector from a mechine, and its has four pins of grounds: POWER ground, Signal ground, Chassis ground and digital ground. i need to connect all this grounds somehow, i can connect all of them to the arduino directly althought they are diffrent grounds?
Thank you,
Power, signal and digital grounds should all come together at the Arduino. Avoid connecting them elsewhere, if possible.
Chassis ground depends on if this thing is powered from a 3 pin power cord. It should be earthed to the earth pin. If it is a battery operated thing then connect it to power ground at one point in the system, which can be the Arduino.
The mechine is 3 pin cord and not battery operated. i have some questions:
Thank you,
So i need to connect the Chassis ground to the earth pin?
Thank you,
In general, yes. For your specific device that you keep secret from us, I don't know. I don't even want to know.
MKS 247D P6 Connector
what are these ground types:
(im using MKS 247D machine)
Thank you,
