i made a project which calculates travelled distance. but there is a problem. because of gps error , device thinks that you re moving . although i am standing exact same location, my device think that i am moving and "travelled distance" increases. what is the ways of avoid this?
1- i think that i made rare calculation it decrease. so i made each measurement in every 10 seconds. it works but not enough
2- maybe i can put my code speed condition. so bellow 2 km/h not accumulates.
what is ur recommendation to solve this problem? any approach is acceptable for me and you can make comment about my code. i am a little noob:D
thank you
mycode:
#include <SoftwareSerial.h>
#include <TinyGPS.h>
TinyGPS gps;
SoftwareSerial ss(3, 4);
//distance
float slat=39;
float slon=27;
unsigned long age=0;
unsigned long sum_distance1=0;
unsigned long sum_distance2=0;
int distance=0;
//timer
unsigned long previousMillis = 0;
unsigned long currentMillis = 0;
//sensor
#define sensorpin A0
int sensor;
#include "U8glib.h"
U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_NONE);
ss.begin(9600);
pinMode(sensorpin,INPUT);
//opening screen
u8g.firstPage();
do {
u8g.setFont(u8g_font_profont12);
u8g.setPrintPos(0, 10);
u8g.print("Mesafe Olcer");
u8g.setPrintPos(0, 25);
u8g.print("GPS'ye baglaniyor");
u8g.setPrintPos(0, 40);
} while (u8g.nextPage() );
while(1){
smartdelay(1000);
gps.f_get_position(&slat, &slon, &age);
Serial.print("slat: "); Serial.println(slat,6);
Serial.print("slon: "); Serial.println(slon,6);
if(slat>1 && slat<100) break;
u8g.firstPage();
do {
u8g.print("=");
delay(10);
Serial.println("--------------------");
smartdelay(1000);
uint8_t sat =gps.satellites();
Serial.print("sat: "); Serial.println(sat);
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
Serial.print("flat: "); Serial.println(flat,6);
Serial.print("flon: "); Serial.println(flon,6);
float spd=gps.f_speed_kmph();
Serial.print("spd "); Serial.println(spd);
int year;
byte month, day, hour, minute, second, hundredths;
unsigned long age2;
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age2);
hour+=3;if(hour>=24)hour-=24;
// sensor
sensor=analogRead(sensorpin);
Serial.print("sensor: "); Serial.println(sensor);
//distance measurement
currentMillis=millis();
if(currentMillis - previousMillis >= 10000){
distance = TinyGPS::distance_between(flat, flon, slat, slon);
if (distance>250 || distance<0 ) distance=0; //set distance 0 if measure larger
else{
slat=flat;
slon=flon;
sum_distance1=sum_distance1+distance;
if (sensor>350 ) sum_distance2=sum_distance2+distance;
Serial.print("sum_distance: "); Serial.println(sum_distance1);
Serial.print("sum_distance2: "); Serial.println(sum_distance2);
Serial.print("distance "); Serial.println(distance);
previousMillis=currentMillis;
//print oled
u8g.firstPage();
do {
u8g.print(sat);
u8g.setPrintPos(64, 10);
u8g.print(distance);
u8g.print(hour);
u8g.setPrintPos(10, 25);
u8g.print(":");
u8g.setPrintPos(20, 25);
u8g.print(minute);
if (sensor>350){
u8g.setPrintPos(64, 25);
u8g.print("++++");
u8g.print("top: "); u8g.print(sum_distance1);
u8g.setPrintPos(64, 40);
u8g.print("sen: "); u8g.print(sum_distance2);
u8g.setPrintPos(0, 55);
u8g.print("hiz: ");
u8g.print(spd);
delay(10);
// u8g.firstPage();
// do {
// draw2();
// } while (u8g.nextPage());
// delay(3500);
static void smartdelay(unsigned long ms)
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
