Arduino HELP PLEASEEEEEE.
int trafficLights1[] = {2,3,4,5}; // red, yellow, green, pedestrians led pins
int trafficLights2[] = {6,7,8,9}; // red, yellow, green, pedestrians led pins
int situations = 4;
int duration[] = {8000,3000,10000,3000}; // duration of each situation
long previousCars = 0;
long previousPeds = 0;
long interval = 0; //blink interval for pedestrians
int ledState = LOW;
int state;
int i = 0;
for(int i = 0; i < 4; i++) {
pinMode(trafficLights1*, OUTPUT);*
_ pinMode(trafficLights2*, OUTPUT);_
_
}_
_
Serial.begin(9600);_
_
}_
_
{_
_
unsigned long currentMillis = millis(); _
_ if(currentMillis - previousCars < duration) {
situation(i);
previousCars = currentMillis;
if(i >= situations) {
i = 0;
i++;
void activateTrafficLight1(String lights, int pedestrians)
for(int x = 0; x < 3; x++)
if(lights[x] == '0') state = LOW;
if(lights[x] == '1') state = HIGH;
digitalWrite(trafficLights1[x], state);
if(pedestrians == 1) {
blinkPed(trafficLights1[3]);
digitalWrite(trafficLights1[3], LOW);
void activateTrafficLight2(String lights, int pedestrians)
digitalWrite(trafficLights2[x], state);
blinkPed(trafficLights2[3]);
digitalWrite(trafficLights2[3], LOW);
void situation(int i)
switch(i){
case 0:
activateTrafficLight1("100",1); // 100 means red ON, yellow OFF, green OFF*
* activateTrafficLight2("001",0); // the second parameter is for pedestrians*
* break; // 1 is ON and 0 is OFF*
* case 1:
activateTrafficLight1("100",0); // 110: red ON, yellow ON, green OFF*
* activateTrafficLight2("010",0);
case 2:
activateTrafficLight1("001",0);
activateTrafficLight2("100",1);
case 3:
activateTrafficLight1("010",0);
activateTrafficLight2("100",0);
void blinkPed(int ped) {
if(currentMillis - previousPeds > interval) {
previousPeds = currentMillis;
if (ledState == LOW)
ledState = HIGH;
else*
* ledState = LOW;
digitalWrite(ped, ledState);
this is my code for traffic intersection
where when the light is green than the pedestrian light should be solid
and when the light is yellow the pedestrian light should flash
and when its red the pedestrian light should be solid
the light from both sides work fine but the only problem is that the led is not flashing at yellow.
please help_
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup(such as the bullets and italics above), leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. Using code tags and other important information is explained in the How to use this forum post. Please read it.
