Arduino + HMC5883L read all 0
I am testing the Arduino + HMC5883L, and Serial Monitor shown all 0, why?
Thanks for help.
Adam
#include "Wire.h"
// I2Cdev and HMC5883L must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "HMC5883L.h"
// class default I2C address is 0x1E
// specific I2C addresses may be passed as a parameter here
// this device only supports one I2C address (0x1E)
HMC5883L mag;
int16_t mx, my, mz;
#define LED_PIN 13
bool blinkState = false;
    // join I2C bus (I2Cdev library doesn't do this automatically)
    Wire.begin();
    // initialize serial communication
    // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
    // it's really up to you depending on your project)
    Serial.begin(38400);
    // initialize device
    Serial.println("Initializing I2C devices...");
    mag.initialize();
    // verify connection
    Serial.println("Testing device connections...");
    Serial.println(mag.testConnection() ? "HMC5883L connection successful" : "HMC5883L connection failed");
    // configure Arduino LED for
    pinMode(LED_PIN, OUTPUT);
    // read raw heading measurements from device
    mag.getHeading(&mx, &my, &mz);
    // display tab-separated gyro x/y/z values
    Serial.print("mag:\t");
    Serial.print(mx); Serial.print("\t");
    Serial.print(my); Serial.print("\t");
    Serial.print(mz); Serial.print("\t");
// To calculate heading in degrees. 0 degree indicates North
    float heading = atan2(my, mx);
    if(heading < 0)
      heading += 2 * M_PI;
    Serial.print("heading:\t");
    Serial.println(heading * 180/M_PI);
    // blink LED to indicate activity
    blinkState = !blinkState;
    digitalWrite(LED_PIN, blinkState);
Are you sure that the HMC5883L is not a fake?
An I2C scanner. What address (if any) show up when you run this?
// I2C scanner by Nick Gammon.  Thanks Nick.
#include <Wire.h>
  Serial.begin (115200); //*****  make sure serial monitor baud matches *****
  // Leonardo: wait for serial port to connect
  while (!Serial)
  Serial.println ();
  Serial.println ("I2C scanner. Scanning ...");
  byte count = 0;
  Wire.begin();
  for (byte i = 1; i < 120; i++)
    Wire.beginTransmission (i);
    if (Wire.endTransmission () == 0)
      Serial.print ("Found address: ");
      Serial.print (i, DEC);
      Serial.print (" (0x");
      Serial.print (i, HEX);
      Serial.println (")");
      count++;
      delay (1);  // maybe unneeded?
      } // end of good response
  } // end of for loop
  Serial.println ("Done.");
  Serial.print ("Found ");
  Serial.print (count, DEC);
  Serial.println (" device(s).");
}  // end of setup
void loop() {}
What Arduino board?
A photo of your wiring is often useful.
groundFungus:
#include <Wire.h>
 while (!Serial)
Serial.println ();
 byte count = 0;
 Wire.begin();
     count++;
}  // end of setup
void loop() {}
What Arduino board?
Thanks.
I attached pictures at my first post, cause of I don't know how to attache them here.
The wiring is just Vcc/GND/SCL(A5)/SDA(A4).
*And the I2C Scanning got address 0x0D, The chip used is DB 5883, maybe I should use HMC5883 Lib instead of HMC5883L? *
That is not an HMC5883L chip. Try the QMC5883 library.
jremington:
Thank you ! Great Job!
