I'm trying to send an image from SPIFFS to my external server. When pictures are taken, they are saved into "/pics/" directory within SPIFFS. Ultimately, I'd like to post all the images saved onto "/pics/x.jpg" (x is the a number in increasing order - 7.jpg, 8.jpg, 9.jpg, etc...) to my external server as they come in. Currently, I can access all the images within the internal esp server. Right now, I'm trying to send a single image, "6.jpg" from "/pics/" to my external server. Unfortunately, I'm not seeing anything on the external server side. The http post code occurs in "void setup()". The most relevant Arduino code is below:
// Program header files
WiFiClient client;
void myCAMsaveToSPIFFS()
// Reserves space when memory is full
if((fileTotalKB - fileUsedKB) < fileSpaceOffset)
String maxStr = "========= Maximum Data Storage Reached =========";
Serial.println(maxStr);
errMsg = maxStr;
return;
String str;
// Flush the FIFO
myCAM.flush_fifo();
// Clear capture done flag
myCAM.clear_fifo_flag();
// Start capture
myCAM.start_capture();
Serial.println("Start capture.");
while(!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
Serial.println("Capture done!");
// Increase file count since a capture was done
fileCount++;
len = myCAM.read_fifo_length();
Serial.print("The FIFO length is: ");
Serial.println(len, DEC);
if(len >= MAX_FIFO_SIZE) // 8M
Serial.println("Over size!");
if(len == 0) // 0 KB
Serial.println("Size is 0 KB.");
str = "/pics/" + String(fileCount) + ".jpg";
File f = SPIFFS.open(str, FILE_WRITE);
if(!f)
Serial.println("Property file failed to open");
Serial.println(str);
i = 0;
myCAM.CS_LOW();
myCAM.set_fifo_burst();
while (len--)
temp_last = temp;
temp = SPI.transfer(0x00);
//Read JPEG data from FIFO
if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
buf[i++] = temp; //save the last 0XD9
//Write the remain bytes in the buffer
myCAM.CS_HIGH();
f.write(buf, i);
//Close the file
f.close();
Serial.println("CAM Save done!");
is_header = false;
i = 0;
if (is_header == true)
//Write image data to buffer if not full
if (i < 256)
buf[i++] = temp;
//Write 256 bytes image data to file
myCAM.CS_HIGH();
f.write(buf, 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
else if ((temp == 0xD8) & (temp_last == 0xFF))
is_header = true;
buf[i++] = temp_last;
buf[i++] = temp;
void camCapture(ArduCAM myCAM)
WiFiClient client = server.client();
if (len >= MAX_FIFO_SIZE) // 8M
Serial.println("Over size.");
if (len == 0 ) // 0KB
Serial.println("Size is 0.");
myCAM.CS_LOW();
if (!client.connected()) return;
i = 0;
while ( len-- )
temp_last = temp;
buffer[i++] = temp; //save the last 0XD9
if (!client.connected()) break;
client.write(&buffer[0], i);
is_header = false;
i = 0;
myCAM.CS_HIGH();
if (i < bufferSize)
buffer[i++] = temp;
//Write bufferSize bytes image data to file
client.write(&buffer[0], bufferSize);
i = 0;
buffer[i++] = temp;
is_header = true;
buffer[i++] = temp_last;
buffer[i++] = temp;
SPIFFS.begin();
delay(10);
Wire.begin();
SPI.begin();
SPI.setFrequency(4000000); //4MHz
pinMode(CS, OUTPUT);
pinMode(ArduCAM_Power, OUTPUT);
digitalWrite(ArduCAM_Power, HIGH);
if (wifiType == 0)
if(!strcmp(WIFI_SSID,"SSID"))
Serial.println(F("Please set your SSID"));
while(1);
if(!strcmp(WIFI_PASSWORD,"PASSWORD"))
Serial.println(F("Please set your PASSWORD"));
while(1);
// Connect to WiFi network
Serial.print(F("Connecting to "));
Serial.println(WIFI_SSID);
WiFi.mode(WIFI_STA);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
while (WiFi.status() != WL_CONNECTED)
Serial.print(F("."));
Serial.println(F("WiFi connected"));
Serial.println("");
File normPicture = SPIFFS.open("/pics/6.jpg", FILE_READ);
uint32_t jpgLen = normPicture.size();
Serial.print("Sending image of ");
Serial.print(jpgLen, DEC);
Serial.println("bytes");
// Prepare request
String start_request = "";
String end_request = "";
start_request = start_request + "\n" + "--AaB03x" + "\n" + "Content-Type: image/jpeg" + "\n" + "Content-Disposition: form-data; name=\"fileToUpload\"; filename=\"6.jpg\"\n" + "Content-Transfer-Encoding: binary\n\n";
end_request = end_request + "\n--AaB03x--\n";
uint32_t extra_length;
extra_length = start_request.length() + normPicture.size() + end_request.length();
//Serial.println("Extra length:");
//Serial.println(extra_length);
long leng = jpgLen + extra_length;
// Connect to server
Serial.println("Starting connection to external server!");
if (client.connect("172.xx.xx.x", 80))
Serial.println("Connected");
client.print("POST /www/upload.php HTTP/1.1");
client.println("Host: 172.xx.xx.x" );
client.println("Content-Type: multipart/form-data; boundary=AaB03x");
client.print("Content-Length: ");
client.println(extra_length);
client.println();
client.print(start_request);
Serial.println("Connected1");
while(normPicture.available())
client.write(normPicture.read());
Serial.println("END REQUEST");
client.println(end_request);
Serial.println("Connection failed!");
// Setup handlers for internal server
server.on("/capture", HTTP_GET, serverCapture);
server.on("/stream", HTTP_GET, serverStream);
server.on("/submit", handleSubmit);
server.on("/clear", clearData);
server.onNotFound(handleNotFound);
server.begin();
Serial.println("Internal Server started");
File dir = SPIFFS.open("/pics");
while(dir.openNextFile())
fileCount++;
fileTotalKB = (int)SPIFFS.totalBytes();
fileUsedKB = (int)SPIFFS.usedBytes();
server.handleClient();
My php code (upload.php) is below:
<?php
if (!empty($_FILES) && isset($_FILES['fileToUpload'])) {
switch ($_FILES['fileToUpload']["error"]) {
case UPLOAD_ERR_OK:
$target = "upload/";
$target = $target . basename($_FILES['fileToUpload']['name']);
if (move_uploaded_file($_FILES['fileToUpload']['tmp_name'], $target)) {
$status = "The file " . basename($_FILES['fileToUpload']['name']) . " has been uploaded";
$imageFileType = pathinfo($target, PATHINFO_EXTENSION);
$check = getimagesize($target);
if ($check !== false) {
echo "File is an image - " . $check["mime"] . ".
$uploadOk = 1;
echo "File is not an image.
$uploadOk = 0;
$status = "Sorry, there was a problem uploading your file.";
echo "Status: {$status}
\n";
I don't believe that I need any html code, since the php file receives the image and sends it to the "uploads/" folder in "www/uploads/" from my external server. My upload.php file is located in "www/".
Thanks!
