I am trying to makes some request - reply protocol between two Arduino. Master Arduino request some data from slave Arduino and depend what is the request it send back required commands.
There is example codes:
Master:
#include <Wire.h>
#include <Arduino.h>
Wire.begin();
//Wire.setClock(333000L); //333000
int address=0x55;
Wire.beginTransmission(address);
Wire.write(0xA2); // must act as a position pointer
Wire.endTransmission();
Wire.requestFrom(address, 32); // request 32 bytes from slave device
delay(20);
Wire.write(0xA8); // must act as a position pointer
Wire.requestFrom(address, 1); // request 32 bytes from slave device
Slave:
#include <Wire.h>
byte answer1[]={0xA1, 0, 0x01, 0x0E, 0x0E, 0x05, 0, 0, 0, 0, 0, 0x01, 0x20, 0x18, 0x11, 0x07, 0x01, 0, 0, 0x95, 0, 0, 0, 0, 0x80, 0x01, 0x49, 0xB9, 0x80, 0xC8, 0x60, 0x2F};
byte answer2[]={0x20, 0x08, 0x3D,0x5B,0, 0, 0xBE, 0x06,0x2C, 0x6A, 0xBB, 0x83, 0x95, 0xCA, 0x5F, 0x34};
Wire.begin(0x55); // join i2c bus with address #55
Wire.onReceive(receiveEvent); // register event
Serial.begin(115200); // start serial for output
//delay(1);
//Serial.println("***********");
void receiveEvent(int howMany)
byte x = Wire.read();// receive byte as an integer
//Serial.print(" Just reading: ");
//Serial.println(x, HEX); // print the integer
if (x==0xA2)
Wire.beginTransmission(0x55);
Wire.write(answer1,32);
//Wire.write(0x02);
//Serial.println(" sending answer1 ");
//for(int i = 0; i < 31; i++) {Serial.print(answer1[i], HEX);}
//Serial.println(" Finish sending first answer...");
if (x==0xA8)
Wire.write(0x10);
Serial.println(" Sending byte 0x10 to request from A8 ");
Serial.println(" Finish sending 0x10 ");
When I am checking on logic analyzer I am expecting some data please have a look attached file.
However currently I am getting first byte 0 and all the rest is FF
Can you point me where I am wrong.
