Arduino IDE 2 (beta) How to configure indent spaces
I'm trying to configure the IDE Editor, to use 4 spaces instead of 2. I was able to configure version 1 of the IDE changing preferences.txt (editor.tabs.size=4), and formatter.conf (indent=spaces=4). But I cannot find those configuration nor anything similar con Arduino IDE 2 (beta).
Does someone know hot to do this??
Cheers!!!
There are two separate systems to configure:
  • Indentation style while editing
  • Indentation style of the auto formatter
I'll provide instructions you can follow to configure both these things to use your preferred number of spaces:
Editor
The editor behavior can be configured in Arduino IDE's advanced settings:
  1. Press the Ctrl+Shift+P keyboard shortcut (Command+Shift+P for macOS users) to open the "Command Palette".
    A menu will appear on the editor toolbar:
  2. Select the "Preferences: Open Settings (UI)" command from the menu.
    You can scroll down through the list of commands to find it or type the name in the field.
    A "Preferences" tab will open in the Arduino IDE main panel.
  3. Type editor.tabSize in the "Search Settings" field of the "Preferences" tab.
  4. Set the field under the "Editor: Tab Size" setting to your preferred number of spaces.
  5. Close the Preferences tab by clicking its X icon.
Auto Format
The sketch code can be automatically formatted to a standardized style by selecting Tools > Auto Format from the Arduino IDE menus. It is possible to define a custom formatter configuration.
The configuration system is documented in general here:
https://docs.arduino.cc/software/ide-v2/tutorials/ide-v2-customize-auto-formatter
The standardized formatter configuration file is available from the link in that tutorial. If you would like the formatter to use a different number of spaces, use that file, but change the value of the relevant properties.
For example, if you want an indent of 4 spaces, change this line:
IndentWidth: 2
To this:
IndentWidth: 4
Related discussion:
