Hello.
I want the 'Arduino15' folder to be on the D: drive, so I used ‘mklink’ to achieve this. Unfortunately, for some reason, the Arduino IDE isn't working properly – it always wants to load some libraries when it starts. When it's on the C: drive, everything works fine. What could be the problem?
Hi @PRLJacek. Which version of Arduino IDE are you using (e.g., "2.3.6")? The version is shown on the window title bar and also in the dialog that opens when you select Help > About (or Arduino IDE > About Arduino IDE for macOS users) from the Arduino IDE menus.
I ask for this information because I want to give you the appropriate instructions for the IDE version you are using.
Please provide a more detailed description of what you mean by this.
Are you drawing this conclusion from a message you see in Arduino IDE? If so, please provide the full and exact text of the message.
Hi, it is 2.3.6 version.
Please look at this picture:
https://moj.pl/obraz/1.jpg
Arduino IDE stores various files in the "data folder".
The default location of the "data folder" is:
C:\Users\<username>\AppData\Local\Arduino15\
(Where <username> is your Windows username)
However, the location is configurable via a configuration file. The location of the configuration file is:
C:\Users\<username>\.arduinoIDE\arduino-cli.yaml
(where <username> is your Windows username)
The "data folder" location is configured via the directories.data key in that configuration file.
So my recommended solution is to do this:
- Select File > Quit from the Arduino IDE menus if it is running.
All Arduino IDE windows will close.
- Remove the symbolic link/directory junction/whatever you created using
mklink.
- Start any text editor application.
- Open the file at the following path on your hard drive:
- Add the following lines to the bottom of the
arduino-cli.yaml file:directories:
data: <data folder path>
- Replace the
<data folder path> placeholder with the full path of the location you want to use for the "data folder" (e.g., D:\Arduino15).
- Save the file.
Thank you very much for your help! It works fine now.
The problem is solved.
You are welcome. I'm glad it is working now.
Regards, Per
