Arduino IDE cannot find Time library even though it exists
I'm experiencing with DS1307 RTC module and installed the libraries. Arduino IDE cannot find the library "TimeLib.h" eventhough it exists. Any help is appreciated.
images included.
This is not an in-built library. You have to download it from here and install.
Hi @monem_dhn.
There is a bug in the sketch compiler that causes it to fail to find the library when it is installed under a path that contains this sort of character.
The workaround will be to configure Arduino IDE to use a different path to store libraries. I'll provide instructions you can follow to do that:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Click the "BROWSE" button on the right side of the "Sketchbook location" field.
    The "Select a new sketchbook location" dialog will open.
  3. Select a folder in any location that contains only basic ASCII characters (the characters A-z, 0-9, _, -, . are safe).
    :warning: Make sure to pick a location that will be safe to store your files since, in addition to containing installed libraries, the sketchbook is a convenient location to save your sketches.
  4. Click the "Choose" button in the "Select a new sketchbook location" dialog.
  5. Click the "OK" button in the "Preferences" dialog.
  6. Move all the files from the folder at the path of the old sketchbook location:
    c:\Users\monem\OneDrive\المستندات\Arduino
    to the folder at the path of the new sketchbook location you set in the Arduino IDE preferences.
Once you have finished performing the instructions above, try compiling your sketch again. Hopefully the compilation will be successful this time.
I installed the library Time-master but the problem still exists !!
Thank you. The problem solved. I appreciate.
:rose:
You are welcome. I'm glad it is working now.
Regards,
Per
