I have a problem, which is every time I try to upload a sketch to a board, the IDE crashes. I've tried uploading to both Arduino Uno and Mega 2560. Both have the same issue. My first thought was that it is a Java problem, but after looking at the error log, I'm not longer sure. I have to mention, I'm using Mac OSX Lion and Arduino 0101
Here is the error log:
Process: JavaApplicationStub [5731]
Path: /Applications/Arduino.app/Contents/MacOS/JavaApplicationStub
Identifier: cc.arduino.Arduino
Version: 1.0.1 (0101)
Code Type: X86 (Native)
Parent Process: launchd [332]
Date/Time: 2012-07-20 15:35:18.182 -0400
OS Version: Mac OS X 10.7.4 (11E53)
Report Version: 9
Crashed Thread: 21 Java: Thread-89
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000b1fb4b70
VM Regions Near 0xb1fb4b70:
Stack 00000000b1db6000-00000000b1eb4000 [ 1016K] rw-/rwx SM=COW
Stack 00000000bc000000-00000000bf800000 [ 56.0M] ---/rwx SM=NUL
Application Specific Information:
objc[5731]: garbage collection is OFF
Java information:
Exception type: Bus Error (0xa) at pc=000000001fa0290c
Java VM: Java HotSpot(TM) Client VM (20.8-b03-424 mixed mode macosx-x86)
Current thread (00000000033a8400): JavaThread "Thread-89" [_thread_in_native, id=-1340592128, stack(00000000b0083000,00000000b0183000)]
Stack: [00000000b0083000,00000000b0183000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j gnu.io.RXTXPort.interruptEventLoop()V+0
j gnu.io.RXTXPort.removeEventListener()V+55
j gnu.io.RXTXPort.close()V+91
j processing.app.Serial.dispose()V+57
j processing.app.debug.Uploader.flushSerialBuffer()V+64
j processing.app.debug.AvrdudeUploader.uploadViaBootloader(Ljava/lang/String;Ljava/lang/String;)Z+854
j processing.app.debug.AvrdudeUploader.uploadUsingPreferences(Ljava/lang/String;Ljava/lang/String;Z)Z+154
j processing.app.Sketch.upload(Ljava/lang/String;Ljava/lang/String;Z)Ljava/lang/String;+14
j processing.app.Sketch.exportApplet(Ljava/lang/String;Z)Z+53
j processing.app.Sketch.exportApplet(Z)Z+8
j processing.app.Editor$DefaultExportHandler.run()V+29
j processing.app.Editor$DefaultExportHandler.run()V+91
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
Java Threads: ( => current thread )
00000000033a0c00 JavaThread "Image Fetcher 1" daemon [_thread_blocked, id=-1312100352, stack(00000000b1baf000,00000000b1caf000)]
0000000003c57800 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=-1313157120, stack(00000000b1aad000,00000000b1bad000)]
=>00000000033a8400 JavaThread "Thread-89" [_thread_in_native, id=-1340592128, stack(00000000b0083000,00000000b0183000)]
0000000003b9a800 JavaThread "DestroyJavaVM" [_thread_blocked, id=-1332187136, stack(00000000b0187000,00000000b0987000)]
000000000344d800 JavaThread "TimerQueue" daemon [_thread_blocked, id=-1309986816, stack(00000000b1db3000,00000000b1eb3000)]
0000000003467c00 JavaThread "Timer-0" daemon [_thread_blocked, id=-1311043584, stack(00000000b1cb1000,00000000b1db1000)]
0000000003431400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=-1314213888, stack(00000000b19ab000,00000000b1aab000)]
0000000003ca3400 JavaThread "Poller SunPKCS11-Darwin" daemon [_thread_blocked, id=-1315270656, stack(00000000b18a9000,00000000b19a9000)]
0000000003c9e400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=-1316327424, stack(00000000b17a7000,00000000b18a7000)]
0000000003ca5800 JavaThread "AWT-Shutdown" [_thread_blocked, id=-1318449152, stack(00000000b15a1000,00000000b16a1000)]
0000000003ca5000 JavaThread "AWT-AppKit" daemon [_thread_in_native, id=-1403710784, stack(00000000bf800000,00000000c0000000)]
0000000003c53800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1320562688, stack(00000000b139d000,00000000b149d000)]
0000000003c52800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=-1321619456, stack(00000000b129b000,00000000b139b000)]
0000000003c51800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1322676224, stack(00000000b1199000,00000000b1299000)]
0000000003c50800 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=-1323732992, stack(00000000b1097000,00000000b1197000)]
0000000003c4b800 JavaThread "Finalizer" daemon [_thread_blocked, id=-1324789760, stack(00000000b0f95000,00000000b1095000)]
0000000003c4a800 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1325846528, stack(00000000b0e93000,00000000b0f93000)]
Other Threads:
0000000003c47c00 VMThread [stack: 00000000b0d91000,00000000b0e91000] [id=-1326903296]
0000000003c55000 WatcherThread [stack: 00000000b149f000,00000000b159f000] [id=-1319505920]
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x9bffdc22 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x9bffd1f6 mach_msg + 70
2 com.apple.CoreFoundation 0x93cfc9da __CFRunLoopServiceMachPort + 170
3 com.apple.CoreFoundation 0x93d05b04 __CFRunLoopRun + 1428
4 com.apple.CoreFoundation 0x93d051dc CFRunLoopRunSpecific + 332
5 com.apple.CoreFoundation 0x93d05088 CFRunLoopRunInMode + 120
6 com.apple.HIToolbox 0x93717723 RunCurrentEventLoopInMode + 318
7 com.apple.HIToolbox 0x9371ea8b ReceiveNextEventCommon + 381
8 com.apple.HIToolbox 0x9371e8fa BlockUntilNextEventMatchingListInMode + 88
9 com.apple.AppKit 0x9737b0d8 _DPSNextEvent + 678
10 com.apple.AppKit 0x9737a942 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 113
11 libawt.jnilib 0x1af05275 -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 132
12 com.apple.AppKit 0x97376cb1 -[NSApplication run] + 911
13 libawt.jnilib 0x1af03598 +[AWTStarter startAWT:] + 2019
14 libawt.jnilib 0x1af02d65 -[CPerformer perform] + 259
15 com.apple.CoreFoundation 0x93d64d11 -[NSObject performSelector:withObject:] + 65
16 com.apple.Foundation 0x9bad6e0c __NSThreadPerformPerform + 503
17 com.apple.CoreFoundation 0x93cdc13f CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION + 15
18 com.apple.CoreFoundation 0x93cdbaf6 __CFRunLoopDoSources0 + 246
19 com.apple.CoreFoundation 0x93d059c8 __CFRunLoopRun + 1112
20 com.apple.CoreFoundation 0x93d051dc CFRunLoopRunSpecific + 332
21 com.apple.CoreFoundation 0x93d05088 CFRunLoopRunInMode + 120
22 com.apple.JavaApplicationLauncher 0x00006268 startupJava(LauncherArgsStruct*) + 304
23 com.apple.JavaApplicationLauncher 0x00009095 launchJavaApplicationWithJVMInfo + 1401
24 com.apple.JavaApplicationLauncher 0x0000599f launchJavaApplication + 39
25 cc.arduino.Arduino 0x00001e8a 0x1000 + 3722
26 cc.arduino.Arduino 0x00001cec 0x1000 + 3308
27 cc.arduino.Arduino 0x00001c19 0x1000 + 3097
Thread 21 Crashed:: Java: Thread-89
0 librxtxSerial.jnilib 0x1fa0290c Java_gnu_io_RXTXPort_interruptEventLoop + 137
1 ??? 0x0400b9d9 0 + 67156441
2 ??? 0x04003e31 0 + 67124785
3 ??? 0x04003e31 0 + 67124785
4 ??? 0x04003e31 0 + 67124785
5 ??? 0x04003e31 0 + 67124785
6 ??? 0x04003e31 0 + 67124785
7 ??? 0x0400405d 0 + 67125341
8 ??? 0x0400405d 0 + 67125341
9 ??? 0x04003f97 0 + 67125143
10 ??? 0x0400405d 0 + 67125341
11 ??? 0x0400405d 0 + 67125341
12 ??? 0x04003e31 0 + 67124785
13 ??? 0x0400430d 0 + 67126029
14 ??? 0x04001374 0 + 67113844
15 libjvm.dylib 0x028adc57 0x2800000 + 711767
16 libjvm.dylib 0x028ad9c9 0x2800000 + 711113
17 libjvm.dylib 0x028ba391 0x2800000 + 762769
18 libjvm.dylib 0x028ba221 0x2800000 + 762401
19 libjvm.dylib 0x028ba19f 0x2800000 + 762271
20 libjvm.dylib 0x028b9ff9 0x2800000 + 761849
21 libjvm.dylib 0x028b9e37 0x2800000 + 761399
22 libjvm.dylib 0x028140dc 0x2800000 + 82140
23 libsystem_c.dylib 0x9177ded9 _pthread_start + 335
24 libsystem_c.dylib 0x917816de thread_start + 34
Thread 21 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x1fa02891 ecx: 0xb018287c edx: 0xffffffff
edi: 0x00000036 esi: 0xb1fb4a30 ebp: 0xb0182908 esp: 0xb01828e0
ss: 0x00000023 efl: 0x00010286 eip: 0x1fa0290c cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000023 gs: 0x0000000f
cr2: 0xb1fb4b70
Logical CPU: 0
It is not the complete log, but I think this is sufficient enough. Any help/advise is appreciated!
