Arduino IDE go creazy with variable B1 and B0
I wrote code like this:
void setup() { } void loop() { } void something(int A1){ }
1
Click verify and no errors. After a while I got bored with variable A1 and change it to B1. So the code become like this:
void setup() { } void loop() { } void something(int B1){ }
Click verify and got ERROR! -_-"
exit status 1 expected ',' or '...' before numeric constant
2
tried this with another computer got same result.
whats going on?
whats going on?
B1 is clearly #defined somewhere, with some value that causes problem where you use B1.
B1 is a silly name. Surely, a longer name would be more meaningful.
The Arduino environment has B00000000 to B11111111 defined to enable them to be used in place of the equivalent binary numbers.
Try this
  Serial.println(B0);
  Serial.println(B1);
  Serial.println(B10);
  Serial.println(B11);
  Serial.println(B11111111);
silly me, Thanks
