Hi everyone,
I'm trying to send numbers from the IDE serial monitor to a Siemens IOT2040 and then to my Ubidots account.
My code appears to work fine for the first number, but when I try to send a second time it crashes. It shows the message "B0100000063f694" in the serial monitor, and then it gets stuck.
I print a serial message after the client.stop() command and the client.connect(server,80) to check which one was causing the problem.
char* payload = (char *) malloc(sizeof(char) * 20);
int value = 0;
EthernetClient client;
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
delay(50);
while (!Serial) {
; /* wait for serial port to connect */
Serial.println("connecting...");
if (client.connect(server, 80)) {
Serial.println("connected");
else {
/* if you didn't get a connection to the server: */
Serial.println("connection failed");
digitalWrite(LED_BUILTIN, LOW);
Serial.println("Ready to transmit");
if (Serial.available() > 0) {
value = Serial.parseInt();
Serial.print("Serial Value: ");
Serial.println(value,DEC);
sprintf(payload, "{\"%s\":%d}", variable_label, value);
client.stop();
delay(10000);
Serial.println("Reaches this point");
Serial.println("transmiting");
/* Make the HTTP request to the server*/
writeToUbidots(device_label, token, payload);
else {
Serial.println("transmition failed");
if (client.available()) {
char c = client.read();
Serial.print(c);
/* if the server's disconnected, stop the client: */
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
/* do nothing forevermore: */
for (;;)
void writeToUbidots(const char* device_label,const char* token, char* payload){
int content_length = strlen(payload) + 2;
client.print(F("POST /api/v1.6/devices/"));
client.print(device_label);
client.println(F(" HTTP/1.1"));
client.println(F("Host: industrial.api.ubidots.com"));
client.println(F("User-Agent: siemenes/1.1"));
client.print(F("X-Auth-Token: "));
client.println(token);
client.println(F("Connection: close"));
client.println(F("Content-Type: application/json"));
client.print(F("Content-Length: "));
client.println(String(content_length));
client.println();
client.print(payload);
client.println();
free(payload);
return ;
How do I avoid it from crashing?
This is the first time I'm doing this kind of project so let me know is there a better way to continuously send data (serial or otherwise) to the cloud.
Thanks everyone!
