Arduino IDE on Fedora 15 Not Working.
I did installation of Arduino IDE on my Fedora 15 system.
Using the GUI option it isn't opening. When I type "arduino" on terminal
then I get following message:
[root@chetanpatil ~]# arduino
/usr/bin/build-classpath: error: Could not find RXTXcomm Java extension for this JVM
/usr/bin/build-classpath: error: Some specified jars were not found
Exception in thread "main" java.lang.NoClassDefFoundError: gnu/io/CommPortIdentifier
at processing.app.Editor.populateSerialMenu(Editor.java:984)
at processing.app.Editor.buildToolsMenu(Editor.java:695)
at processing.app.Editor.buildMenuBar(Editor.java:480)
at processing.app.Editor.(Editor.java:202)
at processing.app.Base.handleOpen(Base.java:699)
at processing.app.Base.handleOpen(Base.java:664)
at processing.app.Base.handleNew(Base.java:561)
at processing.app.Base.(Base.java:301)
at processing.app.Base.main(Base.java:190)
Caused by: java.lang.ClassNotFoundException: gnu.io.CommPortIdentifier
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
... 9 more
After this nothing happens and terminal gets hanged.
I did Google for this but wasn't successful in getting a solution.
As per the above error I think, I have deleted some .jar and .so files.
I followed this for configuration : http://arduino.cc/playground/Linux/Fedora
Please revert if anyone has a solution or suggestion.
Thank You!
I would try downloading the Arduino IDE from the Arduino site.
Select your OS and unpack the files into a local directory.
Try running that "arduino" without modifications.
