Arduino IDE 'Port already in use'
hi
i am using the arduino now for a few years and i love it!!!
today i got a little problem and after searching for hours in the web i don't know what to do now but lets go step by step.
the last week i updated my os to MacOS 10.7 Lion.
today i wanted to start a new arduino project.
i installed the arduino IDE and the driver for the serial controller on the board.
i installed java runtime enviroment version SE 6 from Apple Inc.
i can select the board and i can select the right serial port, in my case: cu.usbserial-A800elg2 for the arduino duemilanove
but when i try to upload the code the error message is:
Binary sketch size: 1018 bytes (of a 30720 byte maximum)
processing.app.SerialException: Serial port '/dev/cu.usbserial-A800eIg2' already in use. Try quiting any programs that may be using it.
at processing.app.Serial.(Serial.java:144)
at processing.app.Serial.(Serial.java:76)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:75)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:93)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:56)
at processing.app.Sketch.upload(Sketch.java:1603)
at processing.app.Sketch.exportApplet(Sketch.java:1568)
at processing.app.Sketch.exportApplet(Sketch.java:1524)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2293)
at java.lang.Thread.run(Thread.java:680)
processing.app.debug.RunnerException: Serial port '/dev/cu.usbserial-A800eIg2' already in use. Try quiting any programs that may be using it.
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:99)
i have also tried it with a arduino mega and a arduino pro mini 5V.
i couldn't find any other program and i am sure there is none that uses this serial port.
i also tried to use another RXTX library but i couldn't find any that works.
this sucks because i need this for a school project i should make...
i hope anyone of you got an idea who to fix that...
greetins form austira and please excuse my bad english =)
greetins Hoonse
i have an update for you
i have tried a new arduino mega (without the FDTI chip)
it has the same problem.
i really hope that someone knows what to do =(
greetings from austria
Hoonse
At the terminal use "lsof | grep ". It will tell you all the processes using the serial port.
You can either use the full name "/dev/cu.usbmodemXXXXX" or just use "usbmodemXXXX".
Hi and thanks for the awnser.
i tried this but there is no output:
Leeeroys-MacBook-Pro:~ Jenkins$ lsof | grep usbserial-A800elg2
is this good or bad ? =)
greetings Hoonse
The debug output shows a capital-I where appear to have used a lowercase-l. (might just be a font issue.)
I would suggest just using "usbmodem" in the search.
If lsof returns nothing, then no other applications are using the file. (in unix/OSX devices are file-handles.)
i have checked it again with:
Leeeroys-MacBook-Pro:~ Jenkins$ lsof | grep /dec/usbserial
but it makes no difference... could it be a problem with the RXTX library?!
greetings hoonse
I fixed the problem by setting
Chmod 777 /var/lock
And
Chmod 777 /var/spools/uucp
Thanks for the help
Greetings hoonse
Just a +1 for the above solution. I had the exact same problem using an Arduino Uno on OS X 10.7 with the error message "port already in use...etc."
changing permissions for /var/lock and /var/spool/uucp worked like a charm
