I checked all the forums and did all the things . its not loading
heres the logs:
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: D:\Users\EXO\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': D:\Users\EXO\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 8176
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/EXO/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-05-29T13:55:50.822Z root INFO Backend Object.initialize: 3.7 ms [Finished 0.665 s after backend start]
2024-05-29T13:55:50.822Z root INFO Backend Object.configure: 2.9 ms [Finished 0.665 s after backend start]
2024-05-29T13:55:50.823Z root INFO Backend s.onStart: 1.5 ms [Finished 0.665 s after backend start]
2024-05-29T13:55:50.823Z root INFO Backend s.configure: 0.3 ms [Finished 0.691 s after backend start]
2024-05-29T13:55:50.824Z root INFO Backend d.onStart: 0.2 ms [Finished 0.691 s after backend start]
2024-05-29T13:55:50.825Z root INFO Backend d.configure: 0.1 ms [Finished 0.691 s after backend start]
2024-05-29T13:55:50.825Z root INFO Backend d.initialize: 25.3 ms [Finished 0.691 s after backend start]
2024-05-29T13:55:50.826Z root INFO Backend c.onStart: 0.2 ms [Finished 0.691 s after backend start]
2024-05-29T13:55:50.826Z root INFO Backend a.configure: 1.2 ms [Finished 0.692 s after backend start]
2024-05-29T13:55:50.828Z config INFO >>> Initializing CLI configuration...
2024-05-29T13:55:50.828Z root INFO Backend c.initialize: 0.6 ms [Finished 0.693 s after backend start]
2024-05-29T13:55:50.828Z root INFO Backend R.onStart: 0.8 ms [Finished 0.693 s after backend start]
2024-05-29T13:55:50.828Z config INFO Loading CLI configuration from c:\Users\EXO\.arduinoIDE\arduino-cli.yaml...
2024-05-29T13:55:50.829Z daemon INFO Starting daemon from D:\Users\EXO\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-29T13:55:50.829Z root INFO Backend a.initialize: 0.4 ms [Finished 0.694 s after backend start]
2024-05-29T13:55:50.829Z root INFO Backend w.onStart: 1.3 ms [Finished 0.695 s after backend start]
2024-05-29T13:55:50.829Z root INFO Backend r.configure: 1.9 ms [Finished 0.695 s after backend start]
2024-05-29T13:55:50.829Z discovery-log INFO start
2024-05-29T13:55:50.829Z discovery-log INFO start new deferred
2024-05-29T13:55:50.829Z root INFO Backend d.initialize: 0.5 ms [Finished 0.696 s after backend start]
2024-05-29T13:55:50.829Z root INFO Backend y.onStart: 1.9 ms [Finished 0.697 s after backend start]
2024-05-29T13:55:50.829Z root INFO Backend r.configure: 1.5 ms [Finished 0.697 s after backend start]
2024-05-29T13:55:50.829Z root INFO Backend a.onStart: 0.4 ms [Finished 0.698 s after backend start]
2024-05-29T13:55:50.829Z root INFO Backend h.configure: 0.3 ms [Finished 0.698 s after backend start]
2024-05-29T13:55:50.829Z root INFO Backend s.configure: 0.2 ms [Finished 0.699 s after backend start]
2024-05-29T13:55:50.829Z root INFO Backend l.configure: 0.0 ms [Finished 0.699 s after backend start]
2024-05-29T13:55:50.831Z root INFO Theia app listening on http://127.0.0.1:53269.
2024-05-29T13:55:50.831Z root INFO Finished starting backend application: 2.4 ms [Finished 0.701 s after backend start]
2024-05-29T13:55:50.987Z root WARN The local plugin referenced by local-dir:/c%3A/Users/EXO/.arduinoIDE/plugins does not exist.
2024-05-29T13:55:50.987Z root WARN The local plugin referenced by local-dir:/c%3A/Users/EXO/.arduinoIDE/extensions does not exist.
2024-05-29T13:55:50.987Z root WARN The local plugin referenced by local-dir:C:\Users\EXO\.arduinoIDE\plugins does not exist.
2024-05-29T13:55:50.992Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\EXO\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\EXO\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\EXO\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-05-29T13:55:50.992Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-05-29T13:55:50.992Z config INFO Loaded the CLI configuration.
2024-05-29T13:55:51.005Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/EXO/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/EXO/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-05-29T13:55:51.005Z config INFO Validating the CLI configuration...
2024-05-29T13:55:51.005Z config INFO The CLI config is valid.
2024-05-29T13:55:51.005Z config INFO <<< Initialized the CLI configuration.
2024-05-29T13:55:51.145Z root INFO Resolve plugins list: 317.1 ms [Finished 1.014 s after backend start]
2024-05-29T13:55:51.208Z daemon INFO time="2024-05-29T17:25:51+03:30" level=info msg="Using config file: c:\\Users\\EXO\\.arduinoIDE\\arduino-cli.yaml"
time="2024-05-29T17:25:51+03:30" level=info msg="arduino-cli.exe version 0.35.3"
2024-05-29T13:55:51.208Z daemon INFO time="2024-05-29T17:25:51+03:30" level=info msg="Executing `arduino-cli daemon`"
2024-05-29T13:55:51.215Z daemon INFO Daemon is now listening on 127.0.0.1:53270
{"IP":"127.0.0.1","Port":"53270"}
2024-05-29T13:55:51.215Z daemon INFO Daemon is running.
2024-05-29T13:55:51.245Z daemon INFO time="2024-05-29T17:25:51+03:30" level=info msg="Checking signature" index="C:\\Users\\EXO\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\EXO\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-05-29T17:25:51+03:30" level=info msg="Loading hardware from: C:\\Users\\EXO\\AppData\\Local\\Arduino15\\packages"
2024-05-29T13:55:51.245Z daemon INFO time="2024-05-29T17:25:51+03:30" level=info msg="Loading package builtin from: C:\\Users\\EXO\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-05-29T13:55:51.245Z daemon INFO time="2024-05-29T17:25:51+03:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\EXO\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-05-29T17:25:51+03:30" level=info msg="Loading tools from dir: C:\\Users\\EXO\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-05-29T13:55:51.246Z daemon INFO time="2024-05-29T17:25:51+03:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-05-29T13:55:51.246Z daemon INFO time="2024-05-29T17:25:51+03:30" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-05-29T13:55:51.246Z daemon INFO time="2024-05-29T17:25:51+03:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-05-29T13:55:51.246Z daemon INFO time="2024-05-29T17:25:51+03:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-05-29T13:55:51.249Z daemon INFO time="2024-05-29T17:25:51+03:30" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.1_Windows_64bit.zip"
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-05-29T13:55:53.171Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 331.5 ms [Finished 2.119 s after frontend start]
2024-05-29T13:55:53.176Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-05-29T13:55:53.457Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 202.9 ms [Finished 2.427 s after frontend start]
2024-05-29T13:55:55.634Z daemon INFO time="2024-05-29T17:25:55+03:30" level=info msg="Installing tool" Tool="builtin:serial-discovery@1.4.1"
2024-05-29T13:55:55.635Z daemon INFO time="2024-05-29T17:25:55+03:30" level=warning msg="Cannot install tool" Tool="builtin:serial-discovery@1.4.1" error="checking local archive integrity"
time="2024-05-29T17:25:55+03:30" level=info msg="Loading tools from dir: C:\\Users\\EXO\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-05-29T17:25:55+03:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-05-29T17:25:55+03:30" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-05-29T13:55:55.637Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: installing builtin:serial-discovery@1.4.1 tool: Cannot install tool builtin:serial-discovery@1.4.1: checking local archive integrity
2024-05-29T13:55:55.637Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
2024-05-29T13:55:55.637Z daemon INFO time="2024-05-29T17:25:55+03:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-05-29T17:25:55+03:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-05-29T17:25:55+03:30" level=info msg="Loading libraries index file" index="C:\\Users\\EXO\\AppData\\Local\\Arduino15\\library_index.json"
2024-05-29T13:55:55.809Z daemon INFO time="2024-05-29T17:25:55+03:30" level=info msg="Adding libraries dir" dir="C:\\Users\\EXO\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-05-29T13:55:55.809Z daemon INFO time="2024-05-29T17:25:55+03:30" level=info msg="Adding libraries dir" dir="C:\\Users\\EXO\\Documents\\Arduino\\libraries" location=user
2024-05-29T13:55:55.814Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
2024-05-29T13:55:55.814Z daemon INFO time="2024-05-29T17:25:55+03:30" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-05-29T13:55:55.815Z daemon INFO time="2024-05-29T17:25:55+03:30" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-05-29T13:55:55.816Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-05-29T13:55:56.543Z root INFO Deploy plugins list: 317.1 ms [Finished 6.412 s after backend start]
2024-05-29T13:55:57.096Z daemon INFO time="2024-05-29T17:25:57+03:30" level=info msg="Checking signature" index="C:\\Users\\EXO\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\EXO\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-05-29T13:55:57.097Z daemon INFO time="2024-05-29T17:25:57+03:30" level=info msg="Loading hardware from: C:\\Users\\EXO\\AppData\\Local\\Arduino15\\packages"
2024-05-29T13:55:57.097Z daemon INFO time="2024-05-29T17:25:57+03:30" level=info msg="Loading package builtin from: C:\\Users\\EXO\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-05-29T13:55:57.097Z daemon INFO time="2024-05-29T17:25:57+03:30" level=info msg="Checking existence of 'tools' path: C:\\Users\\EXO\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-05-29T17:25:57+03:30" level=info msg="Loading tools from dir: C:\\Users\\EXO\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-05-29T13:55:57.098Z daemon INFO time="2024-05-29T17:25:57+03:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-05-29T13:55:57.098Z daemon INFO time="2024-05-29T17:25:57+03:30" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-05-29T13:55:57.098Z daemon INFO time="2024-05-29T17:25:57+03:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-05-29T13:55:57.098Z daemon INFO time="2024-05-29T17:25:57+03:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-05-29T13:55:57.099Z daemon INFO time="2024-05-29T17:25:57+03:30" level=info msg="Starting download" url="https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.1_Windows_64bit.zip"
2024-05-29T13:56:00.386Z root ERROR Detected an error response during the gRPC core client initialization: code: 13, message: installing builtin:serial-discovery@1.4.1 tool: Cannot install tool builtin:serial-discovery@1.4.1: checking local archive integrity
2024-05-29T13:56:00.386Z daemon INFO time="2024-05-29T17:26:00+03:30" level=info msg="Installing tool" Tool="builtin:serial-discovery@1.4.1"
time="2024-05-29T17:26:00+03:30" level=warning msg="Cannot install tool" Tool="builtin:serial-discovery@1.4.1" error="checking local archive integrity"
time="2024-05-29T17:26:00+03:30" level=info msg="Loading tools from dir: C:\\Users\\EXO\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-05-29T13:56:00.386Z daemon INFO time="2024-05-29T17:26:00+03:30" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-05-29T13:56:00.387Z daemon INFO time="2024-05-29T17:26:00+03:30" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-05-29T13:56:00.387Z daemon INFO time="2024-05-29T17:26:00+03:30" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-05-29T13:56:00.387Z daemon INFO time="2024-05-29T17:26:00+03:30" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-05-29T13:56:00.387Z daemon INFO time="2024-05-29T17:26:00+03:30" level=info msg="Loading libraries index file" index="C:\\Users\\EXO\\AppData\\Local\\Arduino15\\library_index.json"
2024-05-29T13:56:00.387Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not installed
2024-05-29T13:56:00.525Z daemon INFO time="2024-05-29T17:26:00+03:30" level=info msg="Adding libraries dir" dir="C:\\Users\\EXO\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-05-29T13:56:00.525Z daemon INFO time="2024-05-29T17:26:00+03:30" level=info msg="Adding libraries dir" dir="C:\\Users\\EXO\\Documents\\Arduino\\libraries" location=user
2024-05-29T13:56:00.526Z root ERROR Uncaught Exception: Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-05-29T13:56:00.526Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
at D:\Users\EXO\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622877
at E.evaluateErrorStatus (D:\Users\EXO\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async a.<anonymous> (D:\Users\EXO\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
it is Driving me creazy for real !
