ARDUINO IDE + USBASP DONESN´T WORK
Good Morning Friends
I am trying record a uC atmega328p using USBASP. i already check the connections (double check) and all is ok.
The result using arduino:
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
The ciurcuit that i assembly is this:
https://slanla.com/blog/article/zjndo7
After i am install the Avrdude to try circuit work
follow the error result when i am trying make a test using a command:
avrdude -patmega328p -cusbasp -P usb -F -v -U flash:r:/dev/null:i
Someone could help me ? i am trying some days :frowning:
Best regards,
Antonio Carlos
C:\avrdude>avrdude -patmega328p -cusbasp -P usb -F -v -U flash:r:/dev/null:i
avrdude: Version 6.3, compiled on Feb 17 2016 at 09:25:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\avrdude\avrdude.conf"
Using Port : usb
Using Programmer : usbasp
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW Max
W ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 36
00 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 45
00 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 45
00 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0
0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0
0 0x00 0x00
Programmer Type : usbasp
Description : USBasp, USBasp - USB programmer for Atmel AVR controllers - fischl.de
avrdude: auto set sck period (because given equals null)
avrdude: error: program enable: target doesn't answer. 1
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x500000
avrdude: Expected signature for ATmega328P is 1E 95 0F
avrdude done. Thank you.
That error typically indicates that part is connected to the USB asp improperly (or is completely bad) - check for wires shorted to eachother, to supply, and to ground. Check with multimeter to verify continuity.
