Hi, I got the same issue like some of you. I switched to Fedora 41 and tried everything to get Arduino v2 working and here’s what I did:
1. added User to dialout group: sudo usermod -aG dialout $USER
2. created a UDEV-rule for ESP32: echo 'SUBSYSTEM=="tty", ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", GROUP="dialout", MODE="0660"' | sudo tee /etc/udev/rules.d/99-esp32.rules
3. apply new UDEV-rule + reloaded: sudo udevadm control --reload + sudo udevadm trigger
4. checked if ESP32 is detected by system: Bus 001 Device 004: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
5. checked Port Permissions for /dev/ttyUSB0: crw-rw----. 1 root dialout 188, 0 2. Feb 15:05 /dev/ttyUSB0
6. confirmed that my user is in dialout group: wheel dialout
Disclaimer: I'm using a cable which worked on my windows machine, so it can't be the issue. I also tried my Arduino MEGA 2560 which works perfectly on windows, too.
Notes:
-Operating System: Fedora 41.
-Arduino IDE v2 Version: 2.3.4
-Hardware: ESP32 with CP210x
nope, I got no issues. Here you can see the output:
[ 2788.209738] usb 1-2: new full-speed USB device number 4 using xhci_hcd
[ 2788.353219] usb 1-2: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
[ 2788.353227] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2788.353231] usb 1-2: Product: CP2102 USB to UART Bridge Controller
[ 2788.353234] usb 1-2: Manufacturer: Silicon Labs
[ 2788.353236] usb 1-2: SerialNumber: 0001
[ 2788.386783] usbcore: registered new interface driver cp210x
[ 2788.386796] usbserial: USB Serial support registered for cp210x
[ 2788.386831] cp210x 1-2:1.0: cp210x converter detected
[ 2788.391348] usb 1-2: cp210x converter now attached to ttyUSB0
Thanks for quick reply
Sorry, in that case I do not know.
My suspicion is that Fedora added another permissions setting (not sure if worded right) I would find the Fedora forum and ask over there what settings are needed to get read/write access.
Check this reply for use of the serial discovery tool: IDE loses track of CP210x port - #4 by ptillisch. Maybe it helps.
There should be official documentation but I could not immediately find it on the web. I did find GitHub - arduino/serial-discovery: An Arduino IDE pluggable-discovery for Serial ports and you can read the readme.
You were right.
The problem was related to the Flatpak installation of Arduino IDE via Software Store. I found out that Flatpak runs applications in a sandboxed environment, which could restrict access to system resources by default (including USB/serial ports). Even with correct UDEV rules and user permissions set up, the Flatpak version couldn't access these ports.
Solution: I just downloaded the Arduino IDE directly from the official website (zip file) instead of using the Flatpak version, and the ports are now properly detected.
If someone has the same issue as me, here is an easy solution for the Flatpak version.
You only need to install Flatseal from the store and activate device=all. That's it!
