The logo keeps getting smaller and bigger but nothing happens.I’m on win 10. I saw another posts talking about it but didn’t find my problem.Using powershell to open it I get this error (I’ll translate what is in another language):
The following problems were detected during the gRPC client initialization:
[library-index] - code: 9, message: Loading index file:
reading library_index.json: open C:\Users\arthu\AppData\Local\Arduino15\library_index.json:
The system can't find the especified file at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:6283973 at y.evaluateErrorStatus
(C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:6283989) at
process.processTicksAndRejections (node:internal/process/task_queues:95:5) at
async a.<anonymous> (C:\Program Files\Arduino
IDE\resources\app\lib\backend\main.js:2:6283659)
A clean install didn’t help
Hi @deus1abacate. Please provide the full output from the PowerShell terminal. You don't need to translate it.
I'll provide instructions you can follow to do that:
This procedure is not intended to solve the problem. The purpose is to gather more information.
- Close all Arduino IDE windows if the IDE is already running.
- Start Windows "File Explorer".
- Open the Arduino IDE installation folder.
ⓘ The default installation location is at one of the following paths:
- In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
A context menu will open
- Select "Open PowerShell window here" from the menu.
Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
- Type the following command in the PowerShell window:
& ".\Arduino IDE"
- Press the Enter key.
Debug output should now be printed to the PowerShell window as Arduino IDE starts.
- Wait until you are sure the IDE startup has gone into the hang state
(as indicated by no additional output being printed to the terminal).
- Switch back to the PowerShell window if the Arduino IDE window took the focus.
- Press the Ctrl+Shift+A keyboard shortcut.
This will select all the text in the PowerShell window.
- Press the Ctrl+C keyboard shortcut.
This will copy the contents of the PowerShell window to the clipboard.
- Open a reply here on this forum topic by clicking the "Reply" button.
- Click the
<CODE/> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press the Ctrl+V keyboard shortcut.
This will paste the output into the code block.
- Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the "Reply" button to publish the post.
Please let us know if you have any questions or problems while following those instructions.
Hi.
i have same problem.
i install lastest version of Win 10 pro
then i install Arduino IDE 2.3.7
when i run Arduino IDE , white window opened and Arduino Logo get smaller and bigger continous
in power shell i see bellow
Thanks for your help and your time
PS C:\Users\mre\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.7
Checking for frontend application configuration customizations. Module path: C:\Users\mre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\mre\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.7" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.3.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2025-12-17T16:05:25.389Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"arduino-ide"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.7","cliVersion":"1.3.1","buildDate":"2025-12-17T16:05:25.389Z"}
Starting backend process. PID: 3956
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/mre/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2026-01-23T05:11:09.907Z root INFO Backend u.initialize: 37.9 ms [Finished 0.808 s after backend start]
2026-01-23T05:11:09.908Z root INFO Backend Object.initialize: 35.7 ms [Finished 0.808 s after backend start]
2026-01-23T05:11:09.908Z root INFO Backend a.initialize: 2.0 ms [Finished 0.808 s after backend start]
2026-01-23T05:11:09.908Z root INFO Backend a.initialize: 1.6 ms [Finished 0.808 s after backend start]
2026-01-23T05:11:09.908Z root INFO Backend u.initialize: 2.2 ms [Finished 0.809 s after backend start]
2026-01-23T05:11:09.911Z root INFO Backend l.initialize: 37.6 ms [Finished 0.810 s after backend start]
2026-01-23T05:11:09.920Z root INFO configured all backend app contributions
2026-01-23T05:11:09.920Z root INFO Backend l.onStart: 1.9 ms [Finished 0.824 s after backend start]
2026-01-23T05:11:09.921Z root INFO Backend d.onStart: 0.2 ms [Finished 0.824 s after backend start]
2026-01-23T05:11:09.922Z root INFO Backend a.onStart: 0.5 ms [Finished 0.824 s after backend start]
2026-01-23T05:11:09.922Z config INFO >>> Initializing CLI configuration...
2026-01-23T05:11:09.922Z root INFO Backend x.onStart: 0.6 ms [Finished 0.825 s after backend start]
2026-01-23T05:11:09.923Z config INFO Loading CLI configuration from c:\Users\mre\.arduinoIDE\arduino-cli.yaml...
2026-01-23T05:11:09.923Z daemon INFO Starting daemon from C:\Users\mre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2026-01-23T05:11:09.923Z root INFO Backend w.onStart: 0.5 ms [Finished 0.826 s after backend start]
2026-01-23T05:11:09.923Z discovery-log INFO start
2026-01-23T05:11:09.923Z discovery-log INFO start new deferred
2026-01-23T05:11:09.923Z root INFO Backend v.onStart: 0.3 ms [Finished 0.827 s after backend start]
2026-01-23T05:11:09.923Z root INFO Backend a.onStart: 0.1 ms [Finished 0.827 s after backend start]
2026-01-23T05:11:09.929Z root INFO Theia app listening on http://127.0.0.1:52092.
2026-01-23T05:11:09.929Z root INFO Finished starting backend application: 5.9 ms [Finished 0.833 s after backend start]
2026-01-23T05:11:09.943Z root WARN The local plugin referenced by local-dir:/c%3A/Users/mre/.arduinoIDE/plugins does not exist.
2026-01-23T05:11:09.943Z root WARN The local plugin referenced by local-dir:/c%3A/Users/mre/.arduinoIDE/deployedPlugins does not exist.
2026-01-23T05:11:09.943Z root WARN The local plugin referenced by local-dir:C:\Users\mre\.arduinoIDE\plugins does not exist.
2026-01-23T05:11:09.961Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2026-01-23T05:11:09.961Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2026-01-23T05:11:10.028Z root INFO Resolve plugins list: 103.1 ms [Finished 0.931 s after backend start]
2026-01-23T05:11:10.055Z daemon INFO time="2026-01-22T21:11:10-08:00" level=info msg="arduino-cli version 1.3.1"
time="2026-01-22T21:11:10-08:00" level=info msg="Using config file: c:\\Users\\mre\\.arduinoIDE\\arduino-cli.yaml"
time="2026-01-22T21:11:10-08:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:52093
{"IP":"127.0.0.1","Port":"52093"}
2026-01-23T05:11:10.055Z daemon INFO Daemon is running.
2026-01-23T05:11:10.066Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\mre\\Documents\\Arduino","data":"C:\\Users\\mre\\AppData\\Local\\Arduino15"}}
2026-01-23T05:11:10.066Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\mre\\Documents\\Arduino","data":"C:\\Users\\mre\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2026-01-23T05:11:10.066Z config INFO Loaded the CLI configuration.
2026-01-23T05:11:10.075Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/mre/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/mre/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2026-01-23T05:11:10.076Z config INFO Validating the CLI configuration...
2026-01-23T05:11:10.085Z config INFO The CLI config is valid.
2026-01-23T05:11:10.085Z config INFO <<< Initialized the CLI configuration.
2026-01-23T05:11:10.087Z daemon INFO time="2026-01-22T21:11:10-08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2026-01-23T05:11:10.813Z root INFO Deploy plugins list: 888.7 ms [Finished 1.717 s after backend start]
2026-01-23T05:11:11.361Z root INFO creating connection for 1
2026-01-23T05:11:12.576Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 152.8 ms [Finished 2.636 s after frontend start]
2026-01-23T05:11:12.625Z root WARN A command editor.action.toggleStickyScroll is already registered.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2026-01-23T05:11:12.784Z root INFO Start frontend contributions: 437.8 ms [Finished 2.822 s after frontend start]
2026-01-23T05:11:12.784Z root INFO Changed application state from 'init' to 'started_contributions'.
2026-01-23T05:11:12.798Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2026-01-23T05:11:12.798Z root INFO >>> Restoring the layout state...
2026-01-23T05:11:12.848Z root INFO [8eb9b481-54bb-4b8f-a717-d26e323cc78a] Waiting for backend deployment: 89.1 ms [Finished 2.903 s after frontend start]
2026-01-23T05:11:13.594Z root INFO [hosted-plugin: 10288] PLUGIN_HOST(10288) starting instance
[Object: null prototype] {}
2026-01-23T05:11:14.521Z root INFO [8eb9b481-54bb-4b8f-a717-d26e323cc78a] Sync of 23 plugins: 1678.0 ms [Finished 4.581 s after frontend start]
