Here is youtube link
Here is project page link with library links etc
The diagram on working on
Simply I aoplied as per instructions and check a keyboard and a octopad but no action or output on arduino board indicator
Does the midi device have output?
Yes its activated
That's the reason I checked more than one device wothall kinds of settongs
If the midi has output, and the Arduino does not get input, that leaves the optocoupler.
Try changing the 220 ohm resistor on the Rx pin to a 560 ohm resistor.
So is it the damaged one ?
Ok le me check with that
ll update it soon
No nothing is going on anyway
I tried up to 10k value and then remove resistor from there too
But no change
So I checked with an LED at MIDI terminal . . . . That is responding with slight blinks when I press or Hit on device !!!
Found one more link here
There is a four pin opto coupler
Bit different type of design !!
