Not sure if this one fits this forum but found that the most adequate.
My question is; I want to take a input signal from arduino (through a force sensor) and by using this input I want to control a program on the computer. Imagine there is a push button, when I press it, on the app screen where will happen something.
I don't know how this connection between arduino and computer application is made.
Once the comm port on the PC recieves the message, you can do what you like with it. I've used Flash bu there's simpler/free ways, most folks use Processing or LabView I believe.
You can also send the event wireless from the Arduino using an XBee (or BT), with a USB-XBee adaptor hanging off the PC.
Carl
Thanks for your answer.
So, how can I read this data from the interface of arduino. I mean how can I connect the software I wrote.
That kinda confuses me. What I want is playing some .wav files accordingly.
check out processing.org
the IDE was built for stuff like this. It's easy to draw shapes and whatnot while listening to the serial port signal from the arduino.
