Hello!
I've been trying to understand how to use this library with no success:
just to test the library i was simply trying to travel from point y to point y for a start. with no results.
#include "InterpolationLib.h"
const int numValues = 10;
double xValues = 0;
double yValues = 100;
float xValue = 0;
void setup(){
void loop(){
Interpolation::Step(xValues, yValues, numValues, xValue, 0.0);
Serial.println(xValue);
delay(100);
i clearly don't understand how the function works since i'm getting a compiling error. Can someone point me out how to perform this simple task?
I understand how i could simply increment xValues with xValues++ until it targets yValues, but i would like to take advantage of the diferent curves this library offers.
here is the example on the library, notice xValue and xValues are diferent things(took me a while...)
Copyright (c) 2019 Luis Llamas
(www.luisllamas.es)
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific language governing permissions and limitations under the License
double xValues[10] = { 5, 12, 30, 50, 60, 70, 74, 84, 92, 100 };
double yValues[10] = { 150, 200, 200, 200, 180, 100, 100, 150, 220, 320 };
while (!Serial) { ; }
for (float xValue = 0; xValue <= 110; xValue += .25)
Serial.print(Interpolation::Step(xValues, yValues, numValues, xValue, 0.0));
Serial.print(',');
Serial.print(Interpolation::Step(xValues, yValues, numValues, xValue, 0.5));
Serial.print(',');
Serial.print(Interpolation::Step(xValues, yValues, numValues, xValue, 1.0));
Serial.print(',');
Serial.print(Interpolation::SmoothStep(xValues, yValues, numValues, xValue));
Serial.print(',');
Serial.print(Interpolation::Linear(xValues, yValues, numValues, xValue, false));
Serial.print(',');
Serial.print(Interpolation::Linear(xValues, yValues, numValues, xValue, true));
Serial.print(',');
Serial.print(Interpolation::CatmullSpline(xValues, yValues, numValues, xValue));
Serial.print(',');
Serial.println(Interpolation::ConstrainedSpline(xValues, yValues, numValues, xValue));
Thanks in advance!
