Hi, I am attempting to make a TURN ON/OFF LED mini project with my ESP32 DEV MODULE, I want the led connected to my esp32 turns on and off with iot button from dash board web editor OR with physical feedback button connected to pin 16 of my esp32 dev moduel , i have read some documentation at IoT Cloud Variables
It says:
"Let's say we create an integer variable called "sensor_value". To use this in a sketch, we simply use:
sensor_value = analogRead(A0);
We do not need to define the variable anywhere, as it has already been configured in thingProperties.h "
With that it mind I just made a switch in my DASH BOARD and I connected a pull-up button to G16 pin of my ESP32 DEV MODULE.
Here is my code at .ino
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/82dcf978-4086-40b9-bca4-c383ef0b784d
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
bool switch_1;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
pinMode(23,OUTPUT);
pinMode(16, INPUT_PULLUP); //PIN G16 DECLARED AS INPUT FOR MY PHYSICAL BUTTON
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
Since Led is READ_WRITE variable, onLedChange() is
executed every time a new value is received from IoT Cloud.
void onSwitch1Change() {
if(switch_1== true|| button_1 == LOW)
digitalWrite (23,HIGH);
digitalWrite (23,LOW);
// Add your code here to act upon Switch1 change
Here is thingProperties.h where I declared my variable
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char DEVICE_LOGIN_NAME[] = "************************";
const char SSID []************= SECRET_SSID; // Network SSID (name)
const char PASS[]************= SECRET_OPTIONAL_PASS; // Network password (use for WPA, or use as key for WEP)
const char DEVICE_KEY[] = **********************; // Secret device password
void onSwitch1Change();
bool switch_1;
int button_1 = digitalRead (16); //PHYSICAL BUTTON ADDED TO MY ESP32 DEV MODULE
void initProperties(){
ArduinoCloud.setBoardId(DEVICE_LOGIN_NAME);
ArduinoCloud.setSecretDeviceKey(DEVICE_KEY);
ArduinoCloud.addProperty(switch_1, READWRITE, ON_CHANGE, onSwitch1Change);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
