#define G 9
#define B 10
#define R 11
#define interruptPin 2
#define alternate_delay 100
#define rand_delay 200
int mode;
mode=1;
pinMode(interruptPin, INPUT);
//pinMode(R, OUTPUT);
//pinMode(G, OUTPUT);
attachInterrupt(digitalPinToInterrupt(interruptPin), mode_change_isr, RISING);
void pwm_anim()
// fade in from min to max in increments of 5 points:
analogWrite(R, 0);
analogWrite(G, 0);
analogWrite(B, 0);
for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += 5) {
// sets the value (range from 0 to 255):
analogWrite(R, fadeValue);
// wait for 40 milliseconds to see the dimming effect
delay(40);
analogWrite(G, fadeValue);
delay(40);
analogWrite(B, fadeValue);
delay(40);
// fade out from max to min in increments of 5 points:
for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= 5) {
delay(40);
delay(40);
delay(40);
void alternate_flash()
digitalWrite(R, HIGH);
delay(alternate_delay);
digitalWrite(R, LOW);
digitalWrite(G, HIGH);
digitalWrite(G, LOW);
digitalWrite(B, HIGH);
digitalWrite(B, LOW);
void two_color_anim()
delay(40);
delay(40);
delay(40);
delay(40);
delay(40);
delay(40);
interrupts();
switch(mode)
case 1: pwm_anim();
case 2: alternate_flash();
case 3: two_color_anim();
case 4: rand_anim();
case 5: only_red();
case 6: only_green();
case 7: only_blue();
case 8: red_green();
case 9: red_blue();
case 10:green_blue();
case 11:all();
void rand_anim()
switch(random(1, 4))
case 1: digitalWrite(R, HIGH);
delay(rand_delay);
digitalWrite(R,LOW);
case 2: digitalWrite(R, LOW);
delay(rand_delay);
case 3: digitalWrite(R, LOW);
delay(rand_delay);
void only_red()
void only_green()
void only_blue()
void red_green()
void red_blue()
void green_blue()
void all()
void mode_change_isr()
noInterrupts();
if(mode < 11)
++mode;
else if(mode >= 11)
mode=1;
/*if(a==1)
a=2;
a=1;
interrupts();*/
Here is the code.
There is also a button on the board which can also be used to change the mode, on press which will interrupt the arduino to change the mode
