Good moring
I've been working on a joystick setup for a while - for the most part I can get everything to work except the PEC11 Rotary Encoder on the DFRobot MCP23017. The Rotary encoder works fine if attached directly to the Leonardo - but I am struggling to understand how to get it to work on the expansion card.
I began to think its was a hardware issue so I have tried all new hardware, it wasn't that.
So using the 'ioInterrupt' example from the DFRobot_MCP23017 library I am still having issues. As I understand it, with a device attached to both INTA and INTB should prompt a serial print out when an interrupt is detected ? It 's only showing an interrupt on INTB, and without me actually having to rotate the encoder. Even if I remove the wire from INTB so only INTA is connected there is no shown output for INTA.
I know I'm missing something, below the code directly from the expample, any constructive pointers very welcome, many thanks.
* @file ioInterrupt.ino
* @brief IO interrupt, set a pin of a port group(A or B) IO to interrupt mode. When an interrupt occurs on the related port group,
* @n pin INTA(group A) or INTB(group B) will output a High level.
* @n INTA and INTB are used to detect if an interrupt occurs on the pin of port eGPA and eGPB respectively; connect pin INTA and INTB
* @n to main-controller's external interrupt 0 and 1 respectively.
* @n Experiment phenomenon: when the signal change of pin INTA or INTB is detected by main-board, the related interrupt service
* @n function will be executed to print out which pin was interrupted on serial port.
* @copyright Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
* @license The MIT License (MIT)
* @author [Arya](xue.peng@dfrobot.com)
* @version V1.0
* @date 2019-07-18
* @url https://github.com/DFRobot/DFRobot_MCP23017
#include <DFRobot_MCP23017.h>
/*DFRobot_MCP23017 constructor
*Parameter &wire Wire
*Parameter addr I2C address can be selected from 0x20~0x27; the relationship of the DIP switch(A2, A1, A0) and I2C address(0x27)
*is shown below:
* 0 0 1 0 | 0 A2 A1 A0
0 0 1 0 | 0 1 1 1 0x27
0 0 1 0 | 0 1 1 0 0x26
0 0 1 0 | 0 1 0 1 0x25
0 0 1 0 | 0 1 0 0 0x24
0 0 1 0 | 0 0 1 1 0x23
0 0 1 0 | 0 0 1 0 0x22
0 0 1 0 | 0 0 0 1 0x21
0 0 1 0 | 0 0 0 0 0x20
DFRobot_MCP23017 mcp(Wire, /*addr =*/0x27); //constructor, change the Level of A2, A1, A0 via DIP switch to revise I2C address within 0x20~0x27.
//DFRobot_MCP23017 mcp;//use default parameter, Wire 0x27(default I2C address)
//Connect 2 buttons to IO expansion board, one to a pin of port eGPA(eg: eGPA0), the other to a pin of port eGPB(eg: eGPB0)
//Connect INTA to the external interrupt pin0 of UNO, INTB to external interrupt pin1 of UNO.
bool intFlagA = false; //INTA interrupt sign
bool intFlagB = false; //INTB interrupt sign
/*Interrupt service function, prototype void func(int index), index represents the pin which is interrupted*/
void gpa0CB(int index) {
/*pinDescription function is used to convert a pin into string description
Parameter pin, the available parameter is shown below:
eGPA0 eGPA1 eGPA2 eGPA3 eGPA4 eGPA5 eGPA6 eGPA7 eGPA
0 1 2 3 4 5 6 7
eGPB0 eGPB1 eGPB2 eGPB3 eGPB4 eGPB5 eGPB6 eGPB7 eGPB
8 9 10 11 12 13 14 15
String description = mcp.pinDescription(index);
Serial.print(description);
Serial.println(" Interruption occurs!");
void gpb7CB(int index) {
#ifdef ARDUINO_ARCH_MPYTHON
pinMode(P0, INPUT); //use mPython external interrupt, connect INTA to pin 0 of mPython.
pinMode(P1, INPUT); //use mPython external interrupt, connect INTB to pin 1 of mPython.
#else
pinMode(2, INPUT); //use UNO external interrupt 0
pinMode(3, INPUT); //use UNO external interrupt 1
#endif
/*wait for the chip to be initialized completely, and then exit*/
while (mcp.begin() != 0) {
Serial.println("Initialization of the chip failed, please confirm that the chip connection is correct!");
/*pinModeInterrupt function is used to set pin to interrupt mode, and the pin will be automatically set to input mode.
Parameter pin, the available parameter is showm below:
0 1 2 3 4 5 6 7
Parameter mode, the available parameter is shown below:
eLowLevel eHighLevel eRising eFalling eChangeLevel
Low-level interrupt High-level interrupt Rising edge interrupt Falling edge interrupt Double edge interrupts
Parameter cb interrupt service function(with parameter)
Prototype void func(int)
mcp.pinModeInterrupt(/*pin = */ mcp.eGPA0, /*mode = */ mcp.eHighLevel, /*cb = */ gpa0CB); //digital pin 0(eGPA0), interrupt in High level. Generate an interrupt when pin 0 is in High level state.INTA output High level.
mcp.pinModeInterrupt(/*pin = */ mcp.eGPB7, /*mode = */ mcp.eChangeLevel, /*cb = */ gpb7CB); //digital pin 15(eGPB7), double edge interrupts. Generate an interrupt when the status of Pin 15 changes. INTB output High level.
#ifdef ARDUINO_ARCH_MPYTHON //
/* mPython Interrupt Pin vs Interrupt NO
* | | DigitalPin | P0~P20 can be used as external interrupt|
* | mPython |--------------------------------------------------------------|
* | | Interrupt No | use digitalPinToInterrupt(Pn) to query interrupt number |
attachInterrupt(digitalPinToInterrupt(P0) /*query Interrupt NO of P0*/, notifyA, RISING); //Enable the external interrupt of mPython P0; rising edge trigger; connect INTA to P0
attachInterrupt(digitalPinToInterrupt(P1) /*query Interrupt NO of P1*/, notifyB, RISING); //Enable the external interrupt of mPython P1; rising edge trigger; connect INTB to P1
#else
/* Main-board of AVR series Interrupt Pin vs Interrupt NO
* | | DigitalPin | 2 | 3 | |
* | Uno, Nano, Mini, other 328-based |--------------------------------------------|
* | | Interrupt No | 0 | 1 | |
* | | Pin | 2 | 3 | 21 | 20 | 19 | 18 |
* | Mega2560 |--------------------------------------------|
* | | Interrupt No | 0 | 1 | 2 | 3 | 4 | 5 |
* | | Pin | 3 | 2 | 0 | 1 | 7 | |
* | Leonardo, other 32u4-based |--------------------------------------------|
* | | Interrupt No | 0 | 1 | 2 | 3 | 4 | |
/* microbit Interrupt Pin vs Interrupt NO
* | | DigitalPin | P0~P20 can be used as external interrupt |
* | microbit |---------------------------------------------------------|
* |(when used as external interrupt, do not need to set it to input mode via pinMode) | Interrupt No | Interrupt NO is pin value, for instance, the Interrupt NO of P0 is 0, P1 is 1. |
attachInterrupt(/*Interrupt NO*/ 0, notifyA, RISING); //Enable external interrupt 0, connect INTA to the main-controller's digital pin: UNO(2),Mega2560(2),Leonardo(3),microbit(P0)
attachInterrupt(/*Interrupt NO*/ 1, notifyB, RISING); //Enable external interrupt 1, connect INTB to the main-controller's digital pin: UNO(3),Mega2560(3),Leonardo(2),microbit(P1)
#endif
/*Interrupt service function*/
void notifyA() {
intFlagA = true;
void notifyB() {
intFlagB = true;
if (intFlagA) {
intFlagA = false;
/*pollInterrupts function is used to poll if an interrupt occurs on a port group
parameter group, the available parameter is shown below: (default value: eGPIOALL):
eGPIOA eGPIOB eGPIOALL
Port groupA Port groupB Port groupA+B
mcp.pollInterrupts(/*group = */ mcp.eGPIOA);
if (intFlagB) {
intFlagB = false;
mcp.pollInterrupts(/*group = */ mcp.eGPIOB);
