I want to code a joystick on my arduino leonardo and I always got a problem. When I upload my code to my arduino I got no error so its upload to my arduino but my computer do not recognize it. I modified the code from http://www.imaginaryindustries.com/blog/?p=80 to have 6 axis at 16 bit.
I modified those line and it won’t work
From the HID.cpp files
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x26, 0xff, 0xff, // LOGICAL_MAXIMUM (65535)
0x75, 0x08, // REPORT_SIZE (8)
0x09, 0x01, // USAGE (Pointer)
0xA1, 0x00, // COLLECTION (Physical)
0x09, 0x30, // USAGE (x)
0x09, 0x31, // USAGE (y)
0x09, 0x32, // USAGE (z)
0x09, 0x33, // USAGE (rx)
0x09, 0x34, // USAGE (ry)
0x09, 0x35, // USAGE (rz)
0x95, 0x06, // REPORT_COUNT (6)
0x81, 0x02, // INPUT (Data,Var,Abs)
0xc0, // END_COLLECTION
The original files look like that
0x26, 0xff, 0x00, // LOGICAL_MAXIMUM (255)
0x95, 0x06, // REPORT_COUNT (2)
// the report section
#define joyBytes 20 // should be equivalent to sizeof(JoyState_t)
void Joystick_::setState(JoyState_t *joySt)
uint8_t data[joyBytes];
uint32_t buttonTmp;
uint16_t xAxisTmp;
uint16_t yAxisTmp;
uint16_t zAxisTmp;
uint16_t xRotAxisTmp;
uint16_t yRotAxisTmp;
uint16_t zRotAxisTmp;
buttonTmp = joySt->buttons;
xAxisTmp = joySt->xAxis;
yAxisTmp = joySt->yAxis;
zAxisTmp = joySt->zAxis;
xRotAxisTmp = joySt->xRotAxis;
yRotAxisTmp = joySt->yRotAxis;
zRotAxisTmp = joySt->zRotAxis;
data[0] = buttonTmp & 0xFF; // Break 32 bit button-state out into 4 bytes, to send over USB
buttonTmp >>= 8;
data[1] = buttonTmp & 0xFF;
buttonTmp >>= 8;
data[2] = buttonTmp & 0xFF;
buttonTmp >>= 8;
data[3] = buttonTmp & 0xFF;
data[4] = joySt->throttle; // Throttle
data[5] = joySt->rudder; // Steering
data[6] = joySt->brake; // Brake
data[7] = joySt->clutch; // Clutch
data[8] = (joySt->hatSw2 << 4) | joySt->hatSw1; // Pack hat-switch states into a single byte
data[9] = xAxisTmp & 0xFF; // X axis
xAxisTmp >>= 8;
data[10] = xAxisTmp & 0xFF;
data[11] = yAxisTmp & 0xFF; // Y axis
yAxisTmp >>= 8;
data[12] = yAxisTmp & 0xFF;
data[13] = zAxisTmp & 0xFF; // Z axis
zAxisTmp >>= 8;
data[14] = zAxisTmp & 0xFF;
data[15] = xRotAxisTmp & 0xFF; // x Rot axis
xRotAxisTmp >>= 8;
data[16] = xRotAxisTmp & 0xFF;
data[17] = yRotAxisTmp & 0xFF; // Y Rot axis
yRotAxisTmp >>= 8;
data[18] = yRotAxisTmp & 0xFF;
data[18] = zRotAxisTmp & 0xFF; // z Rot axis
zRotAxisTmp >>= 8;
data[19] = zRotAxisTmp & 0xFF;
//HID_SendReport(Report number, array of values in same order as HID descriptor, length)
HID_SendReport(3, data, joyBytes);
// The joystick is specified as using report 3 in the descriptor. That's where the "3" comes from
And The code from Imaginary industries is
// report section
#define joyBytes 13 // should be equivalent to sizeof(JoyState_t)
uint32_t buttonTmp;
buttonTmp >>= 8;
buttonTmp >>= 8;
buttonTmp >>= 8;
data[6] = (joySt->hatSw2 << 4) | joySt->hatSw1; // Pack hat-switch states into a single byte
data[7] = joySt->xAxis; // X axis
data[8] = joySt->yAxis; // Y axis
data[9] = joySt->zAxis; // Z axis
data[10] = joySt->xRotAxis; // rX axis
data[11] = joySt->yRotAxis; // rY axis
data[12] = joySt->zRotAxis; // rZ axis
My modified usapi.h
typedef struct JoyState // Pretty self explanitory. Simple state to store all the joystick parameters
uint16_t xAxis;
uint16_t yAxis;
uint16_t zAxis;
uint16_t xRotAxis;
uint16_t yRotAxis;
uint16_t zRotAxis;
uint8_t throttle;
uint8_t rudder;
uint8_t brake;
uint8_t clutch;
uint8_t hatSw1;
uint8_t hatSw2;
uint32_t buttons; // 32 general buttons
} JoyState_t;
usapi.h from imaginary industries
uint8_t xAxis;
uint8_t yAxis;
uint8_t zAxis;
uint8_t xRotAxis;
uint8_t yRotAxis;
uint8_t zRotAxis;
uint8_t throttle;
uint8_t rudder;
uint8_t hatSw1;
uint8_t hatSw2;
} JoyState_t;
So when I upload my files, my rx and tx leds flash one time every 4 seconds, What I am doing wrong is it the hid.cpp.If you want to know what is my .ino there it is
JoyState_t joySt;
joySt.xAxis = 0;
joySt.yAxis = 0;
joySt.zAxis = 0;
joySt.xRotAxis = 0;
joySt.yRotAxis = 0;
joySt.zRotAxis = 0;
joySt.throttle = 0;
joySt.buttons = 0;
joySt.brake = 0;
joySt.clutch = 0;
joySt.xAxis = random(255);
joySt.yAxis = random(255);
joySt.zAxis = random(255);
joySt.xRotAxis = random(255);
joySt.yRotAxis = random(255);
joySt.zRotAxis = random(255);
joySt.throttle = random(255);
joySt.brake = random(255);
joySt.clutch = random(255);
// Avec des pots oui avec des rotary encoder non
// joySt.xRotAxis = (analogRead(A1) / 4);
// joySt.throttle = (analogRead(A2) / 4);
// joySt.brake = (analogRead(A3) / 4);
// joySt.clutch = (analogRead(A4) / 4);
joySt.buttons <<= 1;
if (joySt.buttons == 0)
joySt.buttons = 1;
delay(100);
// Call Joystick.move
Joystick.setState(&joySt);
Sorry for my bad english… Hope you can help me!
Thanks
EDIT: I forgot to mentioned that I already try the code from imaginary industries and it work. And Why i want to have 16 bit of reading it because I want to put rotary encoders for my diy project it will be 3 rotary encoders for diy Sim racing pedals
