Arduino Math Error
Dear All Have a nice day
This is my program in Arduino
long r;
  r = 1200 * 50;
  Serial.println(r);
Result in serial monitor
But it should be
1200 x 50 = 60,000
please advice
The term on the right hand side is evaluated by the compiler as a signed 2 byte integer value. This leads to an overflow.
If you write an "L" after one of the two factors the compiler knows that the calculation shall be done using the type "long".
UL -> Unsigned long
  r = 1200 * 50L;
Alternatively cast one of the factors as long():
  r = long(1200) * 50;
On the Arduino Uno (and other ATmega based boards) an int stores a 16-bit (2-byte) value. This yields a range of -32,768 to 32,767 (minimum value of -2^15 and a maximum value of (2^15) - 1). On the Arduino Due and SAMD based boards (like MKR1000 and Zero), an int stores a 32-bit (4-byte) value. This yields a range of -2,147,483,648 to 2,147,483,647 (minimum value of -2^31 and a maximum value of (2^31) - 1).
See here https://www.arduino.cc/reference/en/language/variables/data-types/int/
And regarding the U, L, UL read here
https://www.arduino.cc/reference/en/language/variables/constants/integerconstants/
Grate Thanks problem solved
Nice, please mark the thread as solved to save other members time :wink:
(Just saw it's done, thanks!)
