Arduino MEGA 2560 and AD7606B connected via SPI
Hey guys
i need your help! can you give me feedback, is there any misstake i made in my code?
i have a PCB with an Arduino Mega 2560 Rev3 and an AD7606B connected via SPI
the problem is i can only read 0.0V from all Channels but there should be voltage on all Channels
the second problem is, i never get FRSTDATA high when i start reading data.
PAR/SER SEL is tied to a logic high,
there is an external Ref with 2.5V connected
PIN-LIST:
|Analog 00|ADC1|REF_SELECT|
|Digital 31|ADC1|RESET|
|Digital 32|ADC1|BUSY|
|Digital 34|ADC1|CONVSTA, CONVSTB|
|Digital 37|ADC1|OS0|
|Digital 38|ADC1|OS1|
|Digital 39|ADC1|OS2|
|Digital 40|ADC1|!STBY|
|Digital 41|ADC1|RANGE|
|Digital 46|ADC1|DOUTC|
|Digital 47|ADC1|DOUTB|
|Digital 48|ADC1|FRSTDATA|
|Digital 49|ADC1|DOUTD|
|Digital 50|ADC1|DOUTA (MISO)|
|Digital 51|ADC1|SDI (MOSI)|
|Digital 52|ADC1|SCLK|
|Digital 53|ADC1|CS|
#include <SPI.h>
#define REFSEL 0
#define STBY 40
#define BUSY 32
#define RESET 31
#define START_CONVERSION 34 //
#define OS0 37
#define OS1 38
#define OS2 39
#define CS 53
#define MISO 50
#define SCLK 52
#define RANGE 41
#define TOTAL_RAW_BYTES 16//num
uint16_t parsed[8];
float data[8];
initADC();
while(!Serial){}
SPI.begin();
readConversion();
delay(5000);
bool initADC()
pinMode(BUSY, INPUT);
pinMode(FRSTDATA, INPUT);
pinMode(RESET, OUTPUT);
pinMode(START_CONVERSION, OUTPUT);
pinMode(CS, OUTPUT);
pinMode(STBY, OUTPUT);
pinMode(REFSEL, OUTPUT);
pinMode(RANGE, OUTPUT);
analogWrite(REFSEL, 0);
digitalWrite(START_CONVERSION, LOW);
digitalWrite(CS, HIGH);
digitalWrite(STBY,HIGH);
pulse(RESET);
return true;
/*pulse signal*/
void pulse(uint8_t port)
digitalWrite(port, HIGH);
delayMicroseconds(10);
digitalWrite(port, LOW);
// delayMicroseconds(1);
void conversionPulse(uint8_t port)
void readConversion() {
Serial.println("doRead");
pulse(START_CONVERSION);
while (digitalRead(BUSY) == HIGH) {
//delayMicroseconds(1);
Serial.println("BusygetLOW");
SPISettings _setting(1000000,MSBFIRST,SPI_MODE3);
SPI.beginTransaction(_setting);
digitalWrite(CS, LOW);
for (int i = 0 ; i<8 ; i++)
if(digitalRead(FRSTDATA) == HIGH)
Serial.println("FRSTDATA is HIGH");
parsed[i]=SPI.transfer16(0x0000);
SPI.endTransaction();
//END OF RECEPTION
Serial.println("end");
//parseRawBytes();
//DISPLAY THE DATA
for (size_t i = 0; i<8; i++)
data[i]=(float)parsed[i] * 2500.0f / 65536.0f; // REF-voltage is 2.5V
Serial.print(data[i]);
Serial.println("mV");
have you tried the AD7606 arduino library and the example programs?
i have tried this, but is give me the same results.
what does the serial monitor display? - upload as text - select < CODE/ > and paste text where it says “type or paste code here”
how have you connected the AD7606 to the MEGA?
upload a schematic showing the wiring?
Schematic_ADC.pdf (286,4 KB)
the output is:
doRead
BusygetLOW
end
0.00mV
0.00mV
0.00mV
0.00mV
0.00mV
0.00mV
0.00mV
0.00mV
