Le shield fonctionne bien sur un UNO ainsi que mon pc et mon cable RJ45
Le mega fonctionne bien aussi.
Le shield Ethernet ne fonctionne pas sur le mega j'ai essayé d'utiliser les pin 50 à 53 et non toujours pas...
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
modified 02 Sept 2015
by Arturo Guadalupi
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
// disable w5100 while setting up SD
pinMode(10,OUTPUT);
digitalWrite(10,HIGH);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// You can use Ethernet.init(pin) to configure the CS pin
//Ethernet.init(10); // Most Arduino shields
//Ethernet.init(5); // MKR ETH shield
//Ethernet.init(0); // Teensy 2.0
//Ethernet.init(20); // Teensy++ 2.0
//Ethernet.init(15); // ESP8266 with Adafruit Featherwing Ethernet
//Ethernet.init(33); // ESP32 with Adafruit Featherwing Ethernet
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Ethernet WebServer Example");
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// start the server
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
Bonjour,
peux tu éditer ton post #5 pour le mettre conforme à la charte avant que l'ensemble du post parte à la poubelle .....
ton schield est compatible avec la méga il n'y a pas lieu de faire du câblage supplémentaire car il utilise le connecteur icsp sauf pour les "ss" (pin 10 pour ethernet et 4 pour SD)
On the Mega, the hardware SS pin, 53, is not used to select the Ethernet controller chip, but it must be kept as an output or the SPI interface won't work
l'as tu essayé ?
certains disent même qu'il faut le passer en HIGH ... à voir ...
Merci pour ce retour, oui j'ai essayé et cela ne change rien. La partie sd fonctionne très bien.
Je vois énormément de pb sur internet pour les mega et shield ethernet.
Web Server
Circuit:
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEF
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
pinMode(10,OUTPUT);
server.begin();
if (client) {
Serial.write(c);
client.println();
client.println("
if (c == '\n') {
delay(1);
client.stop();
jhonnnyBZH35:
Le cablage est 13 vers 52
12 vers 50
11 vers 51
merci
comme je te l'ai dit il n'y a pas de câblage à faire, tu es en train de court-circuiter des pins de la méga, elle est peut être déjà morte ....
il faut enficher le schield sur la méga et la lib s'occupe de tout sauf qu'il faut rajouter : "pinMode(53, OUTPUT);" juste après la ligne "pinMode(10,OUTPUT);" au code de ton post #7 et voir ce que la console remonte
après il faut vérifier que l'ip choisie est dans la plage de ton réseau pour pouvoir s'y connecter
Web Server
Circuit:
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
modified 15 Jul 2014
by Soohwan Kim
#include <SPI.h>
#if defined(WIZ550io_WITH_MACADDRESS) // Use assigned MAC address of WIZ550io
#else
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
#endif
//#define __USE_DHCP__
IPAddress ip(192, 168, 1, 20);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
// fill in your Domain Name Server address here:
IPAddress myDns(8, 8, 8, 8); // google puble dns
// Enable w5100
pinMode(10,OUTPUT);
pinMode(53,OUTPUT);
while (!Serial) {
// initialize the ethernet device
#if defined __USE_DHCP__
Ethernet.begin();
#else
Ethernet.begin(mac);
#endif
#else
Ethernet.begin(ip, myDns, gateway, subnet);
#else
Ethernet.begin(mac, ip, myDns, gateway, subnet);
#endif
#endif
server.begin();
if (client) {
Serial.write(c);
client.println();
client.println("
if (c == '\n') {
delay(1);
client.stop();
j'ai enlevé le cablage
la console me retourne :
12:44:45.700 -> server is at 0.0.0.0
j'ai fais un nouvel essai : MEGA + Schield ethernet W5100 + IDE 1.8.8 + exemple ethernet webserver (sans rien changer sauf l'@ IP) -> ça fonctionne le serveur délivre toutes les 5 secondes les 5 valeurs analogiques
rjnc38:
c'est étrange puisque dans ethernet.cpp il y a :
void EthernetClass::init(uint8_t sspin)
W5100.setSS(sspin);
il y a des subtilités, si vous allez dans utility/w5100.cpp il y a plein de manips (variant.h par exemple) qui peuvent modifier la pin en question, mais on peut aussi lire
// For boards using AVR, assume shields with SS on pin 10
// will be used. This allows for Arduino Mega (where
// SS is pin 53) and Arduino Leonardo (where SS is pin 17)
// to work by default with Arduino Ethernet Shield R2 & R3.
#elif defined(__AVR__)
#define SS_PIN_DEFAULT 10
// If variant.h or other headers define these names
// use them if none of the other cases match
#elif defined(PIN_SPI_SS)
#define SS_PIN_DEFAULT PIN_SPI_SS
#elif defined(CORE_SS0_PIN)
#define SS_PIN_DEFAULT CORE_SS0_PIN
// As a final fallback, use pin 10
#else
#endif
// Initialise the basic info
if (W5100.init() == 0) return 0;
et dans le fichier ethernet.h il y a comme signature/prototypestatic void init(uint8_t sspin = 10);Donc comme on appelle init() sans paramètre, ça prend la valeur par défaut et le pin select utilisé est bien 10, câblé en dur...
bref à moins que vous ayez une librairie ou une variante qui met le souc, la sspin est bien sur 10
d'ailleurs je ne comprend pas cette recommandation de la doc de la lib :
puisqu'il n'y a pas de lien physique entre la pin 53 et le schield ethernet : les Mosi Miso Clk passent par l'ICSP et les SS par les pins 4 et 10
