I use an Arduino Mega 2560. Since today I have been experiencing a strange problem. The GPIO pins are able to take input and give output but nothing is displayed on the serial monitor.
Has anyone faced this ?
kindly suggest.
Regards,
Venkatesh.
kindly suggest.
Regards,
Venkatesh.
venkeeg:
kindly suggest.
Post your program. Without that we have no idea what you are trying to do.
How is the Mega connected to your PC?
...R
Hi Robin,
Kindly find the code below. I am just trying to glow an LED for any character pressed on the bluetooth terminal installed on my mobile.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10,11);
pinMode(5,OUTPUT);
mySerial.begin(9600);
void loop() // run over and over
if (mySerial.available())
char c = mySerial.read();
if(c >= 97 && c <= 122 || c >= 65 && c <= 90)
digitalWrite(5,HIGH);
Serial.write(c);
//Serial.println(c);
Regards.
Please use the code button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum
Also please use the AutoFormat tool to indent the code for easier reading.
I will do it for you this time
pinMode(5,OUTPUT);
Serial.write(c);
Note that I have inserted a pair of {} for the second IF statement to clarify what it is supposed to do. I may not have done it as you intend.
Why are you using SoftwareSerial on a Mega when it has 3 spare HardwareSerial ports that work much better?
Put a message in setup() to prove that the printing is working - for example
Serial.println("My program is starting");
...R
Please use code tags when posting code. Edit your post, place [code] before your code and [/code] after your code.
Next you're using SoftwareSerial on a Mega. Why? You have 4 hardware serial ports available; use one of those.
I'm not quite sure of the operator precedence; try
if ((c >= 97 && c <= 122) || (c >= 65 && c <= 90))
Hi..
Thanks for the info.
is there a function to read the hardware serial ports ?
Regards.
You use exactly the same functions as for Serial; so e.g. Serial1.begin(), Serial1.read() and so on.
Used Serial2 ( pins 16,17) ..thanks a lot.
