Arduino mega 2560 tx and rx at 3.3v
Hi there, i need to connect a generic wifi shield that works at 3.3v to an arduino mega 2560 r3, but i ve been told that the shield only works at 3.3volt as for power and for data serial communication, but i can't find on the arduino documentation if it is possible to use the serials at that voltage, does anyone knows if this is possible?
Thanks in advance.
Juan
3.3V is higher then the 3V minimum needed for a valid high input at Rx.
Arduino Tx output will be 5V, up to you to reduce that to 3.3V, with resistor voltage divider for example.
Cross thanks for the response i am quite new to arduino and have little knowledge of electronic, using resistor might cause any issue?
Thanks
Juan
Two resistors:
Thanks i will try it!
Juan
