Hello Everyone,
My Plan.
I want to light my home's outer walls with AC Rice LED ( I have at least 200 strips of 70-100 feet 220-240V AC).. With few ardunio mega and many 8 channel relay board
In starting i ordered
1x Arduino Mega
3x 8 channel relay board (5v)
1x ESP8266 Wi-Fi module for switching between LED scripts
I have 4 AXT power supply i converted 2 of them to a bench power supply as source power of my Arduino mega and relay boards... these atx power supply capable of providing 10-20 A at 3.3 v rail, 20-40 A on 5 v rail and 8-20 A on 12 V rail
In starting I want it to be small project and simple.
Few things you all should know about me,
I am good with electronics.
I am good with mechanical parts
But i am very very bad when it comes to codding part...suppose I have zero knowledge of languages..
so i will be needing help with how to write code for switching on and off in sequence and randomly 32 channel relay...
i will appreciate any help you all guys provide.. if anyone can write codes for me...
Today i have downloaded some codes from google and edited it for 8 relays simple on and off
I Want to relay to be Random switch on and off some time chasing anyone one would like guide me in wright way to go ...
/-----( Import needed libraries )-----/
/-----( Declare Constants )-----/
#define RELAY_ON 0
#define RELAY_OFF 1
/-----( Declare objects )-----/
/-----( Declare Variables )-----/
#define Relay_1 2 // Arduino Digital I/O pin number
#define Relay_2 3
#define Relay_3 4
#define Relay_4 5
#define Relay_5 6
#define Relay_6 7
#define Relay_7 8
#define Relay_8 9void setup() /****** SETUP: RUNS ONCE ******/
//-------( Initialize Pins so relays are inactive at reset)----
digitalWrite(Relay_1, RELAY_OFF);
digitalWrite(Relay_2, RELAY_OFF);
digitalWrite(Relay_3, RELAY_OFF);
digitalWrite(Relay_4, RELAY_OFF);
digitalWrite(Relay_5, RELAY_OFF);
digitalWrite(Relay_6, RELAY_OFF);
digitalWrite(Relay_7, RELAY_OFF);
digitalWrite(Relay_8, RELAY_OFF);//---( THEN set pins as outputs )----
pinMode(Relay_1, OUTPUT);
pinMode(Relay_2, OUTPUT);
pinMode(Relay_3, OUTPUT);
pinMode(Relay_4, OUTPUT);
pinMode(Relay_5, OUTPUT);
pinMode(Relay_6, OUTPUT);
pinMode(Relay_7, OUTPUT);
pinMode(Relay_8, OUTPUT);
delay(4000); //Check that all relays are inactive at Reset}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
//---( Turn all 8 relays ON in sequence)---
digitalWrite(Relay_1, RELAY_ON);// set the Relay ON
delay(1000); // wait for a second
digitalWrite(Relay_2, RELAY_ON);// set the Relay ON
digitalWrite(Relay_3, RELAY_ON);// set the Relay ON
digitalWrite(Relay_4, RELAY_ON);// set the Relay ON
digitalWrite(Relay_5, RELAY_ON);// set the Relay ON
digitalWrite(Relay_6, RELAY_ON);// set the Relay ON
digitalWrite(Relay_7, RELAY_ON);// set the Relay ON
digitalWrite(Relay_8, RELAY_ON);// set the Relay ON
delay(4000); // wait see all relays ON//---( Turn all 8 relays OFF in sequence)---
digitalWrite(Relay_1, RELAY_OFF);// set the Relay OFF
digitalWrite(Relay_2, RELAY_OFF);// set the Relay OFF
digitalWrite(Relay_3, RELAY_OFF);// set the Relay OFF
digitalWrite(Relay_4, RELAY_OFF);// set the Relay OFF
digitalWrite(Relay_5, RELAY_OFF);// set the Relay OFF
digitalWrite(Relay_6, RELAY_OFF);// set the Relay OFF
digitalWrite(Relay_7, RELAY_OFF);// set the Relay OFF
digitalWrite(Relay_8, RELAY_OFF);// set the Relay OFF
delay(4000); // wait see all relays OFF}//--(end main loop )---
//( THE END )**
