Arduino Mega Hardware Serial communication with MATLAB
Hello everyone,
So I am trying to send some commands through MATLAB to Arduino Mega. I have used a 9 pin serial bus to USB cable to connect the Hardware Serial 3 of Arduino Mega to the computer. Now when the MATLAB code is running, the arduino starts running for a while and then stops responding. I checked using Serial Monitor and it shows that it is executing the commands but after some time it stops receiving commands. If I close the serial monitor and reopen it again, then the arduino again starts receiving the commands, executes them for a while and again stops receiving commands. I think after some while if (Serial3.available > 0 ) starts returning false. But why this happens and why does it start working as soon as I open the serial monitor? I don't know whether this a hardware problem or a software problem. Can someone please help me with it?
In case you need any other information, please let me know.
Thanks!
Please find the code below:
// This is the Arduino test code is for Robot_2, the one
// with one Sabertooth motor driver and two Odrive motor controllers.
//It will check if the robot is able to run and steer properly
//For Robot 1:
//Right = 381
//Centre = 472
//Left = 575
//30 for left and -30 for right
//updated the steering function
//added PID for steering
//added PID for driving motors
// Libraries
#include <SabertoothSimplified.h>  // SaberTooth motor driver
#include <Sabertooth.h>
#include <SoftwareSerial.h>        // Serial Library
#include "Arduino.h"               // Arduino
#include <avr/io.h>                // General definations of registers
#include <util/delay.h>            // Delay functions
#include <PID_v1.h>                // PID Library
#include <ODriveArduino.h>
#include <HardwareSerial.h>
// Hardware Pin Definitions
// Arduino Mega or Due - Serial1 and Serial2
// Serial1: ODrive1 (motor 1)
// Serial2: ODrive2 (motor 2)
HardwareSerial& odrive_serial1 = Serial1;
HardwareSerial& odrive_serial2 = Serial2;
#define SAB_RX 25  // not used
#define SAB_PORT 43 // SaberTooth S1
#define SAB_ESTOP 45 // SaberTooth S2
#define SteerPot A0 // Potentiomenter measuring the steering of the front wheels
// Define variables and constants
#define LOOPTIME        500000 // looptime = 0.5 s
unsigned long lastMicro = 0;
unsigned long lastMicroPrint = 0;
int baudrate = 19200;  // Must match what you configure on the ODrive (see ODrive documentation)
bool running = false;
bool steering = false;
const double velocity_constant = 2 * 3.1415 * 0.0762;
int motor_speed = 0;
float delta_req = 0;     // requested steering command -30~30 degree
float velocity_req = 0;   // requested velocity command 0~5 m/s
double potRest, angle_act, SteerMotorValue, angle_req;
double speed_req, output_speed, desiredVelocity, speed_act;
// Define the aggressive and conservative Tuning Parameters
double consKp = 0.5, consKi = 0, consKd = 0.15;
// PID parameters for drive motors
double driveConsKp = 1, driveConsKi = 0.0, driveConsKd = 0.1;
// Initialize software serial and hardware Serial for the motor controller
SoftwareSerial SWSerial_Drive(SAB_RX, SAB_PORT);
SabertoothSimplified DriveMotor(SWSerial_Drive);
ODriveArduino odrive1(odrive_serial1);  //left motor
ODriveArduino odrive2(odrive_serial2); //right motor
PID myPIDSteer(&angle_act, &SteerMotorValue, &angle_req, consKp, consKi, consKd, DIRECT);
PID myPIDDrive(&speed_act, &output_speed, &desiredVelocity, driveConsKp, driveConsKi, driveConsKd, DIRECT);
  odrive_serial1.begin(baudrate);
  odrive_serial2.begin(baudrate);
  SWSerial_Drive.begin(9600);
  Serial.begin(38400);  // Serial to PC - Use this with MATLAB directly without Connecting anything
  Serial3.begin(9600); //connect the usb serial port to use this with MATLAB
  delay(10);
  //  Serial.flush();  // Clear
  while (!Serial3) {}   // Flash L4 if we are waiting for a serial connection
  pinMode (SAB_ESTOP, OUTPUT);
  if (Serial3.available() > 0)
    delta_req = Serial3.parseFloat();
    velocity_req = Serial3.parseFloat();
    if (Serial3.read() == '$') //done transmitting
      angle_req = delta_req;
      desiredVelocity = velocity_req;
  Serial.println("Waiting for ODrive1...");
  while (odrive1.getState() == AXIS_STATE_UNDEFINED) {
    delay(100);
  Serial.println("ODrive1 connected!");
  Serial.println("Waiting for ODrive2...");
  while (odrive2.getState() == AXIS_STATE_UNDEFINED) {
    delay(100);
  Serial.println("ODrive2 connected!");
  // Initialize ODrive controllers to closed-loop control mode
  initializeODrive(odrive1);
  initializeODrive(odrive2);
  myPIDDrive.SetMode(AUTOMATIC);
  potRest = (double)analogRead(SteerPot);
  angle_act = angleCali(potRest);
  angle_req = 0;
  myPIDSteer.SetMode(AUTOMATIC);
  myPIDSteer.SetOutputLimits(-127, 127);
  DriveMotor.motor(1, 0);
  DriveMotor.motor(2, SteerMotorValue);
  //  DriveMotor.motor(1, SteerMotorValue); // Steering Motor
  Serial.println("Code Started");
  if (Serial3.available() > 0) {
      desiredVelocity = ((velocity_req / velocity_constant) * 3);
      Serial.println(desiredVelocity);
      start_motors(desiredVelocity);
      processMotor2(angle_req);
      PrintServoPosition(angle_req);
      if ((micros() - lastMicro) >= LOOPTIME)
        lastMicro = micros();
        if (desiredVelocity <= 0) {
          start_motors(0);
        else {
void brakes_off() {
  Serial.println("Brakes Disenaged");
  DriveMotor.motor(1, 127);
void brakes_on() {
  Serial.println("Brakes Engaged");
void start_motors(double speed_req) {
  ODriveFeedback feedback1 = odrive1.getFeedback();
  ODriveFeedback feedback2 = odrive2.getFeedback();
  desiredVelocity = speed_req;
  double speed_act = (double)feedback1.vel;
  myPIDDrive.Compute();
  Serial.println("_________");
  Serial.println(output_speed);
  odrive1.setVelocity(-output_speed);
  odrive2.setVelocity(output_speed);
  Serial.print("Motor 1 - pos:");
  Serial.print(feedback1.pos);
  Serial.print(", vel:");
  Serial.print(feedback1.vel);
  //  delay(1000);
  Serial.print(" - Motor 2 - pos:");
  Serial.print(feedback2.pos);
  Serial.print(feedback2.vel);
void all_stop() {
  odrive1.setVelocity(0);
  odrive2.setVelocity(0);
// Steer motor PID
void processMotor2(double angle)
  double angle_req = angle;
  double gap = angle_req - angle_act;
  Serial.println(gap);
  if (abs(gap) < 2 || abs(gap) > 40) {
    SteerMotorValue = 0;
    //    DriveMotor.motor(2, SteerMotorValue);
    steering = false;
  else {
    myPIDSteer.SetTunings(consKp, consKi, consKd);
    myPIDSteer.Compute();
    Serial.println(SteerMotorValue);
    steering = true;
  while (steering) {
    double tolerance = 2.0;
    double potValue = (double)analogRead(SteerPot);
    angle_act = angleCali(potValue);
    int angleDifference = angle_req - angle_act;
    Serial.println("------------------");
    Serial.println(angle_act);
    Serial.println(angle_req);
    Serial.println(angleDifference);
    if (SteerMotorValue == 0) {
      DriveMotor.motor(2, 0);
      Serial.println("Angle Reached");
      steering = false;
    else if (SteerMotorValue < 15 || SteerMotorValue > 40) {
      SteerMotorValue = 20;
    if (abs(angleDifference) <= tolerance) {
      steering = false;
    else if (angleDifference < 0) {
      Serial.println("Going Right");
    else {
      Serial.println("Going Left");
      DriveMotor.motor(2, -SteerMotorValue);
// Calibration of the SteerPot reading to front wheel steering angles
double angleCali(double x)  // x is the reading of the TurnPot A0 (463~705)
  //  double y = 0.26446281 * x - 154.446281;
  //double y = 0.32653 * x - 154.1224; //2023
  double y = 0.32979 * x - 151.7042;
  return (double)y; // return the current angle y, degrees
void PrintServoPosition(double orderAngle)
  double potRest = (double)analogRead(SteerPot);
  double currAngle = angleCali(potRest);
  double angleError = orderAngle - currAngle;
  Serial.print("Requested Angle: ");
  Serial.print(orderAngle);
  Serial.print("  Real Position:");
  Serial.print(currAngle);
  Serial.print("  Error:");
  Serial.println(angleError);
  //delay(400);
void initializeODrive(ODriveArduino & odrive) {
  odrive.clearErrors();
  //  odrive.setState(AXIS_STATE_ENCODER_OFFSET_CALIBRATION);
  //  while (odrive.getState() != AXIS_STATE_IDLE) {
  //    delay(10);
  while (odrive.getState() != AXIS_STATE_CLOSED_LOOP_CONTROL) {
    odrive.setState(AXIS_STATE_CLOSED_LOOP_CONTROL);
    delay(10);
  start_motors(0);
Opening the Serial monitor resets the Mega. Could this be a clue to the problem ?
That’s not a robust way to listen to Serial3
I would suggest to study Serial Input Basics to handle this
