Hi all;
Two pins of my Arduino mega won't drop to zero voltage in LOW state (A1 and D48)
Any idea???
Hi all;
Any idea???
Show the code that you're using to test. Is anything connected to those pins?
Nothing connected to all pins;
I tried many codes:
use this code to put all the pins at the low state:
for (int X = 0; X<=68; X=X+1)
pinMode(X, OUTPUT);
digitalWrite(X, LOW);
pinMode(48, OUTPUT);
digitalWrite(48, LOW);
Sorry, forgot to ask earlier. How do you know that they don't drop? Multimeter? Which voltage does it read?
Thanks for your response;
I read voltage with a voltmeter
A1 = 2.2 v
D48 = 4.8 v
All other pins = 0.2 ~ 0.5 v (in low state)
Sounds like the part has been damaged, probably through electrical abuse (voltages higher than Vcc, lower than ground on pin, or excessive current through pin; the former is very good at doing that, the latter less so)
Try as suggested here, or just try configuring and testing pin 48 independently to see if it makes a difference.
I don't think you want to mess with pins 0 and 1 (RX/TX) and pin numbers above 53.
