Im encountering problem with pwm on pins 0 and 1 is it even possible ?
Im also sharing the measuring from the osciloscope the blue on is working pwm and the yellow on is D1
Can you please clarify exactly which Arduino board you are using ?
It is normally the case that PWM capable pins on Arduino boards are marked with a tilde character ( ~ )
Based on @ruilviana's pinout, the answer is no. Also be aware that pins 0 and 1 are the serial interface for communication with the PC.
