arduino mega serial talking with strings
hi all, i am trying to communicate a serial device (pic 12f) with arduino mega. i connected device to serialport3. when i send command 'g' to serialport3, device blinks a led and sends a sentence like "ok now\n\r". i send 'g' command to the device by sending 'a' command to arduino. also i want to see the device's reply from arduino serial monitor. i see the led blinks but i couldn't read the sentence. i am trying to modify serial event skecth, where problem can be?
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
inputString.reserve(200);
  Serial3.begin(9600);
  // reserve 200 bytes for the inputString:
   if (Serial.available())
   char ser = Serial.read();
   if(ser == 'a'){
   Serial3.write('g');
  if (stringComplete) {
    Serial.println(inputString);
    // clear the string:
    inputString = "";
void serialEvent() {
  while (Serial3.available()) {
    // get the new byte:
    char inChar = (char)Serial3.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      stringComplete = true;
use insert code.
Moderator edit: Dummy code tags corrected.
There is a world of difference between a string and a String. The sooner that you learn what that one little letter difference means, the better.
I call by brother Tom by the name of George...
   if(ser == 'a'){
   Serial3.write('g');
Thanks for posting all this... Is your delete key broken?
You need to reserve 200 characters to hold a one letter command? Are you serious?
What sentence? The only code to output anything is commented out.
